 Post subject: Donor for WD with no DCM WD10SDRW-11A0XS1
PostPosted: October 19th, 2025, 4:41
Hello everyone,
How can I find a donor HDD for drives that don’t have a DCM code on the label? Some WD drives, like the Charger and Palmer families, don’t list a DCM—only the model number, serial number, manufacture date, and location are provided.
Currently, I have the following drive:
Model: WD10SDRW-11A0XS1
Family: Palmer
Made in: Thailand
Date: 24 OCT 2024
PCB: 2060-800069-001
I'm trying to find a suitable donor for a head swap, but I’m not sure what parameters to match without the DCM. Is the model number, manufacture date, and country of origin enough, or is there anything else I should look for?
 Post subject: Re: Donor for WD with no DCM WD10SDRW-11A0XS1
PostPosted: October 19th, 2025, 5:45
Most of donors will work fine but you can check DCM in moduje 47 or 0A. Or just check it in log after running the utility.
odzyskiwanie danych
PostPosted: October 21st, 2025, 0:04
Thanks for your response.
Right now, I don’t have any donor drives, so I’m trying to find one. Do you think the WD10SDRW-1A0XS0 would be compatible? The PCB number is the same: 800069.
PostPosted: October 21st, 2025, 0:31
Probably will work.
odzyskiwanie danych
Users browsing this forum: Google [Bot] and 69 guests
