 Post subject: Need donor ROM for ST1000LM037
PostPosted: December 5th, 2022, 3:04
Hi i need donor ROM for Seagate ST1000LM037, problem with the drive ,wont spin up and no error in terminal, tried patient rom in donor pcb no result looking for donor rom in order to import adaptives to give a try. Attached patient rom as well
File comment: Patient Rom attached
ROM_WN94YR1H_37077191.rar [250.8 KiB]
Downloaded 218 times
 Post subject: Re: Need donor ROM for ST1000LM037
PostPosted: December 5th, 2022, 23:10
Try the attached repair.
ROM_WN94YR1H_37077191_no_spin_repaired.7z [244.36 KiB]
Downloaded 230 times
PostPosted: December 6th, 2022, 2:31
Hi fzabkar it works after writing the rom which you sent ,even ace ts cant fix it they ended up stating adaptives are corrupt and it cant be fixed, your gr8 man thank you for your effort can you share me what did you do i can see a small dword changes in the offset 78C50 ,it will be gr8 if you share us.
PostPosted: December 6th, 2022, 5:37
SFW got corrupt, that's easy to see, wondering why they suspected adaptives...
Franc probably copied it from the inactive container.
PostPosted: December 6th, 2022, 12:37
You can use F3RomExplorer to analyse the ROM:
http://www.hddoracle.com/download/file.php?id=8721
The SFW segment in the active container (BFWContainer1) had a bad CRC. This turned out to be an error in a single bit. There was a good copy of the SFW segment in the inactive container, BFWContainer0. I compared the two copies and used the good copy to repair the bad.
Good copy of SFW
00038C40  5B FC 94 DD 2B E2 8F 1E 3D 08 02 E1 A1 29 04 21
00038C50  00 E4 10 10 0D C0 AD 00 22 02 64 08 60 24 C0 1B
00038C60  00 21 02 94 FB 0F 03 B0 F9 8F 08 8E 7F F0 FE BD
Bad copy of SFW
00078C40  5B FC 94 DD 2B E2 8F 1E 3D 08 02 E1 A1 29 04 21
00078C50  00 E4 10 10 0D C0 AD 01 22 02 64 08 60 24 C0 1B
00078C60  00 21 02 94 FB 0F 03 B0 F9 8F 08 8E 7F F0 FE BD
PostPosted: December 8th, 2022, 2:27
Thank you so much for the information appreciate your effort fzabkar
