 Post subject: Format password locked Toshiba MQ01ABU050W
PostPosted: January 13th, 2023, 12:49
Hi.
I got a lot of discarded disks that can't be formatted. Apparently they were blocked using bitlocker but I'm not 100% sure.
Smart info shows:
ATA Security: ENABLED, PW level MAX, **LOCKED** [SEC4]
And lots of Interface CRC errors.
Could I low level format them or use them in any way? I couldn't do anything using dd or dban, nor any other tool that I know of.
Maybe there's an IC that could changed or re-programmed?
 Post subject: Re: Format password locked Toshiba MQ01ABU050W
PostPosted: January 13th, 2023, 22:25
Spildit wrote:
You need to remove the ATA lock first ....
Options are trying ZU
I just found a thread about this ZU utility and will definitely give it a try.
Spildit wrote:
buying firmware tools like PC-3000/MRT
I can't find anybody that sells this locally. Looks quite nice though.
Spildit wrote:
learn the VSCs to make the drive remove the password by formatting the correct sector
Would you please elaborate more on that? What are the VSCs?
Thanks for mentioning all these alternatives.
PostPosted: January 14th, 2023, 16:06
Spildit, nice to see you again, but ZU doesn't support MQ01ABU050W. For this drive need proper tools as you tell him PC3k, or MRT.
Users browsing this forum: Majestic-12 [Bot] and 68 guests
