 Post subject: Seagate 3TB drive suddenly 'Unallocated'
PostPosted: January 25th, 2023, 19:42
I have a 3tb Seagate drive that was partitioned as a single drive (my D: drive) and suddenly vanished from Windows. Checking with Disk Manager, it now shows as 'Unallocated". All the programs I've used to check the drive don't report any errors (i.e. SMART, etc.), so I'm stumped on what happened. The complete explanation of what I've tried so far is below, but this once in my life I seriously want to recover the data on it, which, unfortunately, I hadn't yet backed up (my bad on that one.)
So far I've tried several different recovery tools with no success (e.g. Disk Drill, Aomei Partition Assistant, Stellar Data Recovery, Recovery It, and maybe one or two others). Each one sees the drive and identifies its model number and will start scanning. But then each of them just runs for hours, even overnight, and never shows more than zero overall progress counting either sectors or blocks or whatever. It does appear that they're working, but they go so slowly that in two instances where they gave an approximate time remaining (in hours) it would have been two years! Disk Drill was the only one that showed it was finding Bad Blocks as it counted up slowly, but even it was apparently going to take thousands of hours to finish.
Seagate support was kind enough to send me one of their tools to try to recover it, and before it started it looked like it estimated maybe five hours to complete. But it's been running now over five hours and still shows 0% overall progress, only on Phase 1 of 4, with 0 files found. Only the elapsed time keeps counting up.
So my question is whether I'm doing something wrong using these programs, or if anyone knows something that will work. I'd love to know what could so affect a drive so completely that recovery programs can't even read it well enough to make any progress or find anything.
Since several of the disk checking tool don't show errors with the drive, I'm not sure what to think or even try next. If there's no option to recover this myself, I'd also be interested in suggestions for highly recommended data recovery companies (ones I might be able to afford for a 3Tb drive.)
Thanks,
JTT
 Post subject: Re: Seagate 3TB drive suddenly 'Unallocated'
PostPosted: January 25th, 2023, 19:59
Can you show us the SMART from CrystalDiskInfo (not SeaTools)?
PostPosted: January 26th, 2023, 1:56
Thanks for mentioning CrystalDiskInfo, I wasn't aware of it. Notably, it reported "Caution" on this drive, in yellow, and also highlighted in yellow the Reallocated Sectors Count. I understand what is meant by 'reallocated sectors' but comparing the results to other drives I couldn't understand why this drive showed caution when the others showed 'good'. I've put the text output below after trying to post an image of the screen (for some reason the site wouldn't take it, saying it wasn't possible to determine the dimensions). Not sure how much of the text is necessary so I'll include as much as I can. Thanks!
CrystalDiskInfo 8.17.13 (C) 2008-2022
(04) ST33000651NS
Model : ST33000651NS
Firmware : G009
Serial Number : Z294BP36
Disk Size : 3000.5 GB (8.4/137.4/3000.5/----)
Buffer Size : Unknown
Queue Depth : 32
# of Sectors : 5860533168
Rotation Rate : 7200 RPM
Interface : Serial ATA
Major Version : ATA8-ACS
Minor Version : ATA8-ACS version 4
Transfer Mode : SATA/600 | SATA/600
Power On Hours : 15778 hours
Power On Count : 615 count
Temperature : 39 C (102 F)
Health Status : Caution
Features : S.M.A.R.T., NCQ, GPL
APM Level : ----
AAM Level : ----
Drive Letter :
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 _82 _63 _44 00000A86CD63 Read Error Rate
03 _91 _91 __0 000000000000 Spin-Up Time
04 100 _99 _20 00000000037E Start/Stop Count
05 100 100 _36 000000000003 Reallocated Sectors Count <<this was the only entry that showed a yellow dot icon (not blue).
07 _43 _43 _30 01A6009B6174 Seek Error Rate
09 _82 _82 __0 000000003DA2 Power-On Hours
0A 100 100 _97 000000000000 Spin Retry Count
0C 100 100 _20 000000000267 Power Cycle Count
B8 100 100 _99 000000000000 End-to-End Error
BB 100 100 __0 000000000000 Reported Uncorrectable Errors
BC 100 _99 __0 000500050005 Command Timeout
BD _99 _99 __0 000000000001 High Fly Writes
BE _61 _49 _45 000027180027 Airflow Temperature
BF 100 100 __0 000000000000 G-Sense Error Rate
C0 100 100 __0 00000000006C Power-off Retract Count
C1 _94 _94 __0 000000003641 Load/Unload Cycle Count
C2 _39 _51 __0 001100000027 Temperature
C3 _22 __4 __0 00000A86CD63 Hardware ECC recovered
C5 100 100 __0 000000000000 Current Pending Sector Count
C6 100 100 __0 000000000000 Uncorrectable Sector Count
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
-- IDENTIFY_DEVICE ---------------------------------------------------------
0 1 2 3 4 5 6 7 8 9
000: 0C5A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2020 2020 2020 2020 5A32 3934 4250 3336
020: 0000 0000 0004 4730 3039 2020 2020 5354 3333 3030
030: 3036 3531 4E53 2020 2020 2020 2020 2020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 4001 2F00
050: 4001 0200 0200 0007 3FFF 0010 003F FC10 00FB 0110
060: FFFF 0FFF 0000 0004 0003 0078 0078 0078 0078 0010
070: 0000 0000 0000 0000 0000 001F 850E 0006 0048 0040
080: 01F0 0029 346B 7D01 4163 3469 BC01 4163 407F 00D7
090: 0001 0000 FFFE 0000 FE00 0000 0000 0000 0000 0000
100: A3B0 5D50 0001 0000 0000 0000 0000 0000 5000 C500
110: 4E60 7537 0000 0000 0000 0000 0000 0000 0000 409E
120: 401C 0000 0000 0000 0000 0000 0000 0000 0021 A3B0
130: 5D50 A3B0 5D50 2020 0002 0140 0100 5000 3C06 3C0A
140: 0000 003C 0000 0008 0000 0000 007F 0280 0000 0000
150: 0008 0000 0000 0000 0000 0000 0000 0000 4400 8808
160: 0000 0000 0000 0000 0000 0000 0000 0000 0002 0000
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 10BD 0000 0000 0000
210: 0000 0000 0000 0000 0000 0000 0000 1C20 0000 0000
220: 0000 0000 1020 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
240: 0000 0000 0000 4000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 D5A5
-- SMART_READ_DATA ---------------------------------------------------------
+0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 0A 00 01 0F 00 52 3F 63 CD 86 0A 00 00 00 03 03
010: 00 5B 5B 00 00 00 00 00 00 00 04 32 00 64 63 7E
020: 03 00 00 00 00 00 05 33 00 64 64 03 00 00 00 00
030: 00 00 07 0F 00 2B 2B 74 61 9B 00 A6 01 00 09 32
040: 00 52 52 A2 3D 00 00 00 00 00 0A 13 00 64 64 00
050: 00 00 00 00 00 00 0C 32 00 64 64 67 02 00 00 00
060: 00 00 B8 32 00 64 64 00 00 00 00 00 00 00 BB 32
070: 00 64 64 00 00 00 00 00 00 00 BC 32 00 64 63 05
080: 00 05 00 05 00 00 BD 3A 00 63 63 01 00 00 00 00
090: 00 00 BE 22 00 3D 31 27 00 18 27 00 00 00 BF 32
0A0: 00 64 64 00 00 00 00 00 00 00 C0 32 00 64 64 6C
0B0: 00 00 00 00 00 00 C1 32 00 5E 5E 41 36 00 00 00
0C0: 00 00 C2 22 00 27 33 27 00 00 00 11 00 00 C3 1A
0D0: 00 16 04 63 CD 86 0A 00 00 00 C5 12 00 64 64 00
0E0: 00 00 00 00 00 00 C6 10 00 64 64 00 00 00 00 00
0F0: 00 00 C7 3E 00 C8 C8 00 00 00 00 00 00 00 00 00
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 82 00 61 02 00 7B
170: 03 00 01 00 01 FF 02 C2 01 00 00 00 00 00 00 00
180: 00 00 00 00 E2 08 00 00 03 09 09 09 09 09 09 09
190: 09 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 40 2B 04 9B 34 A6 00 00
1B0: 00 00 00 00 01 00 05 10 5E 40 CE 3A C5 03 00 00
1C0: FD E9 2D 7C CF 35 00 00 00 00 00 00 FF FF FF FF
1D0: 01 00 00 00 00 00 00 00 F4 00 00 00 83 01 A7 88
1E0: 09 00 00 00 00 00 00 00 09 00 00 00 00 00 03 38
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D7
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 01 00 01 2C 00 00 00 00 00 00 00 00 00 00 03 00
010: 00 00 00 00 00 00 00 00 00 00 04 14 00 00 00 00
020: 00 00 00 00 00 00 05 24 00 00 00 00 00 00 00 00
030: 00 00 07 1E 00 00 00 00 00 00 00 00 00 00 09 00
040: 00 00 00 00 00 00 00 00 00 00 0A 61 00 00 00 00
050: 00 00 00 00 00 00 0C 14 00 00 00 00 00 00 00 00
060: 00 00 B8 63 00 00 00 00 00 00 00 00 00 00 BB 00
070: 00 00 00 00 00 00 00 00 00 00 BC 00 00 00 00 00
080: 00 00 00 00 00 00 BD 00 00 00 00 00 00 00 00 00
090: 00 00 BE 2D 00 00 00 00 00 00 00 00 00 00 BF 00
0A0: 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00
0B0: 00 00 00 00 00 00 C1 00 00 00 00 00 00 00 00 00
0C0: 00 00 C2 00 00 00 00 00 00 00 00 00 00 00 C3 00
0D0: 00 00 00 00 00 00 00 00 00 00 C5 00 00 00 00 00
0E0: 00 00 00 00 00 00 C6 00 00 00 00 00 00 00 00 00
0F0: 00 00 C7 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 84
PostPosted: January 29th, 2023, 19:39
Similar situation happened to me. I scanned my drive for a week with several recovery tools but no success. Only TestDisk reported from start read error. Then, I tried to read the surface with Victoria and discovered that all sectors on the drive are unreadable, while SMART status is GOOD. So I suggest you to do a read test with Victoria or another tool.
