 Post subject: Cutting reading head off, HGST 2.5" 1TB
PostPosted: January 30th, 2023, 0:22
I know in some cases the hard drive reading heads that have platter damage can be cut off.
I have Hitachi 2.5" 1TB (HTS541010A9E632) that has a scratched H1 platter, other platters are okay. Can this model head be cut off and still image the rest of the platters?
Ideas and experience about this would be appreciated.
 Post subject: Re: Cutting reading head off, HGST 2.5" 1TB
PostPosted: January 31st, 2023, 6:49
yes. Basically any HDD can be done like that.
PostPosted: January 31st, 2023, 14:01
I've seen cases (reported by DR pros) where this doesn't work. Is it because the headmap was not edited?
PostPosted: January 31st, 2023, 14:03
I don't know why others cannot do it, i know i can, so it is possible...
PostPosted: January 31st, 2023, 14:13
Some firmware appears to test all the heads during the POST and won't spin up the drive if a head fails.
PostPosted: January 31st, 2023, 14:48
yes, some of them do.
PostPosted: January 31st, 2023, 15:59
I had some problems on Panther B/C drives.
PostPosted: January 31st, 2023, 18:33
Thanks for clues and answers.
So far successful experience cutting WD and Seagate heads and those do need firmware/head map edit.
With this Hitachi drive I have no experience at all, is there something I need to know about it before cutting the head off?
PostPosted: February 1st, 2023, 5:13
It is like fzabkar says.
Newer hdd:s and some older ones checks if all heads are present. Which hdd:s it is that support this you need to find out by yourself.
Instead of cutting you bend the head so its still present but not touching the surface.
PostPosted: February 1st, 2023, 5:22
bending it does not guarantee it will be detected, especially if it is already bad...
PostPosted: February 1st, 2023, 6:34
Of course it is not an guarantee. I did never talk about the detection, i was talking about another way instead of cutting heads.
If patient heads are contaminated and you are able to clean the rest of the heads it could be usable. Up to you as dr engineer to decide.
But safest way is to use new heads if someone is not used to do this type of shit :)
All the best!
Users browsing this forum: Majestic-12 [Bot] and 29 guests
