 Post subject: Need Maxtor 6e040L0510211 KMGA
PostPosted: April 14th, 2005, 7:08
Hello All,
I need the firmware files for 6E040L0510211 KMGA
Your help is appreciated.
leclerc.stephane@globetrotter.net
 Post subject: Re: Need Maxtor 6e040L0510211 KMGA
PostPosted: April 18th, 2005, 6:12
Sphyncteur wrote:
Hello All,
if you have a loader with can start the drive from safe mode, you can read the original modules, and if OVLs are intact, you are able to create an LDR from the patient drive. Then after starting with this one you must be able to write to the SA. Don't forget to make an SA write test before recording modules!
Users browsing this forum: DrZ and 67 guests
