 Post subject: Seagate ST1000DM003 no more detected by BIOS
PostPosted: February 23rd, 2023, 19:03
Hello everyone, I hope someone in this community could help me to understand what's wrong with my old hard drive
Forewords:
All sensible data has been already backuped, so I have no reason to contact an expensive recovery service. I'm trying to do my best only for fun, but only in the last two months I'm discovering how tricky is an HDD (not mentioning the mechanical aspect)
The HDD is quite old (2012) and I've already replaced it with an SSD and moved as secondary disk.
The HDD started to desappear occasionally at latest boots requiring a reboot to be correctly recognized by bios, so its failure wasn't a surprise.
1. The disk never sounded weird, so I thought that replacing the pcb could restore the drive. Of course I was wrong.
2. Searching on this and other forums I tried to apply the "Busy bug" procedure, I stopped after clearing the SMART statistics because I realized that I was on the wrong direction and I could only make it worse
3. While waiting for another ST1000DM003 (used but healthy), eventually to sacrify as "donor", I studied better the Seagate Terminal and I gathered several informations (attached)
Now I'm supposing that the fw Is not loaded, this could explain why the Terminal is unlocked, differently for the "donor" HDD, but I need a confirmation from some expert.
The P-List is readable and huge.
If I'm right and the firmware is not loaded, the next question will be: can I upload the firmware into the ram directly from terminal or at least try to rewrite it? There's a free-ware/trial tool for that?
Thank you in advance for your attention, follows an extract from the console activity attached to the post,
Alessio
from Power On:
Boot 0x40M
Spin Up
Trans.
Spin Up
(P) SATA Reset
ASCII Diag mode
F3 T> (Ctrl + i)
LuxorPlus Rev: 0203; No Host; SpdLimit: 6.0GbMax; SSC: Yes; LED: No; StagSpinByp: Yes;
SATA Block Registers
ATA
800DC000: 0001 0000 0000 0000 0001 0400 0000 0000
800DC010: 0000 0000 4400 0480 0040 0000 0000 0400
800DC020: 0080 0000 0010 0210 0000 0000 0000 0000
800DC030: 0000 E60B 0000 0000 0000 0000 0000 0000
800DC040: 0000 0000 0800 0000 0000 0000 FFFF 003F
800DC050: 4795 57A5 CE2D 0000 0000 0000 0000 0000
80007FD0: 00000000 00000000 00000000 00000000
80007FE0: 00000000 00000000 00000000 00000000
80007FF0: 00000000 00000000 00000000 00000000
Hardware Phy Event Counters
00000000: 0000 0000 0000 0000 0000 0000 0000 0000
00000010: 0000 0000 0000 0000 0000 0000
R_ERR on RX FIS Non-data: 00000, Data: 00000
R_ERR on TX FIS Non-data: 00000, Data: 00000
F3 T> (Ctrl + a)
Package Version: GPG17B.CCD4.AM0247.CC43 , Package P/N: 100711986, Package Global ID: 00188399,
Package Build Date: 07/19/2012, Package Build Time: 09:41:47, Package CFW Version: GPG1.CCD4.00463044.00188399,
Package SFW1 Version: B7E6, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 07190941, CustomerRel: CC43, Changelist: 00463044, ProdType: GPG1.CCD4, Date: 07/19/2012, Time: 094147, UserId: 00188399
Servo FW Rev: B7E6
RAP FW Implementation Key: 16, Format Rev: 0004, Contents Rev: 71 01 07 00
TCG IV Version: n/a
F3 T>J
CAP:
(P1=00) Validation Key: 00000020
(P1=01) HDA Serial Number: S1D4HNPM
(P1=02) PCBA Serial Number: 0000M3041D8N
(P1=03) PCBA Part Number: Invalid
(P1=04) Head Count: 02
(P1=05) Node Name Validation Key: 01
(P1=06) Node Name: 50 00 C5 00 52 00 2B 53
(P1=07) Product Family ID: 58
(P1=08) Product Family ID: 06
(P1=09) PCBA Build Code: Invalid
(P1=0A) ASIC Info:
FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FF FF FF FF FF FF FF FF FF FF FF FF 00
(P1=0B) Firmware Key: FF FF FF FF FF FF FF FF FF FF FF FF FF FF
(P1=0C) Firmware Key Checksum: FFFF
(P1=0D) Date of Manufacture: 08042012
(P1=0E) Destroked Buf Size Index: 03
(P1=0F) Final Mfg Op: Invalid
(P1=10) Final Mfg Erc: Undefined
(P1=11) System Area Prep State: FE
(P1=12) SPT Auto Run Delay: 00
(P1=13) Reserved: 00
(P1=14) Checksum: FFFF
(P1=15) External Model Number: ST1000DM003-1CH162
(P1=16) Internal Model Number: ST1000DM003-1CH162
(P1=17) IDEMA Capacity: 0000000074706DB0
(P1=18) Reserved1:
F3 T>/7
F3 7>X
Head 00 Resistance 0168
Head 01 Resistance 013F
File comment: F3 Terminal log
seagate2.log [3.84 MiB]
Downloaded 271 times
 Post subject: Re: Seagate ST1000DM003 no more detected by BIOS
PostPosted: February 24th, 2023, 11:07
This leads nowhere imo. If the data is not important, why ordering a donor and investing in recovering the bad drive by sacrificing a good one :roll:
There is no point in investing time in posting advices either, even no point in this very post, but i gave some of my time to make it...
PostPosted: February 24th, 2023, 13:50
Try my ZOC script:
ZOC Scripts - Seagate F3 Arch - Set Mode Page Parameters :
http://www.hddoracle.com/viewtopic.php?f=113&t=1867
Answer "N" to the Media Cache prompt, "Y" to all the others.
This script switches off certain aspects of the firmware which are probably causing your drive to remain BSY.
Seagate F3 Arch - Patching the 093 sysfile :
http://www.hddoracle.com/viewtopic.php?f=59&t=1842
PostPosted: February 24th, 2023, 14:06
Head 0 is bad.
You can turn it off and get 500GB HDD.
You need special $$ software (such as SeDiv, MRT,...) and knowledge.
A lot of knowledges. :) Donor is not needed.
PostPosted: February 24th, 2023, 18:23
can't see why would H0 be bad...
PostPosted: February 24th, 2023, 18:31
Ok, my major interest is "to understand", and if I could make the hdd visible again will be a great satisfaction.
So, I thank you all for your replies, but I'd like to know:
1)
SWM wrote:
Head 0 is bad.
SWM says that head 0 is gone. Which information in the log suggests that? The head resistances are quite similar. And why the donor is useless? Couldn't I try to replace the heads?
2)
Try my ZOC script:
I saw this scripting language for the first time, so it will keep me sometime to study about it and other interesting links. Just a couple of questions: can the script make things worse? Referring to the log, there's any clue that the drive is in a BSY state?
thank you again
Alessio
PostPosted: February 24th, 2023, 22:58
The script turns off various firmware settings. It does the same thing as PC3000. A drive often remains BSY if there are pending reallocations.
PostPosted: February 25th, 2023, 4:01
runamok,
seagate2.log:
017A 000006CA95E0 000006CACA6D 0206AA.0.0001 0206AA.0.0001 0809F5 00C11 2F9596 0000000000110001 00000000
017B 000006CA95E1 000006CACA6E 0206AA.0.0002 0206AA.0.0002 081649 00C11 2FA013 0000000000110001 00000000
017C 000006CA95E2 000006CACA6F 0206AA.0.0003 0206AA.0.0003 08229D 00C11 2FABD4 0000000000110001 00000000
3F0B 00000E96216E 00000E98C450 0530DC.0.009F 05343C.0.009F 020914 127E6 285056 0000000000010001 00000000
3F0C 00000E96216F 00000E98C451 0530DC.0.00A0 05343C.0.00A0 0215A6 127E6 285C51 0000000000010001 00000000
3F0D 00000E962AAF 00000E98CD91 0530E7.0.0098 053447.0.0098 00B21F 127E6 287AB1 0000000000110001 00000000
60952 741 284 02 011101 000000 2 43110081 XFR RD USR LBA B 000000000118 L 00000070 BO 24000E74 VL CEBB.0C40
61236 284 741 02 011101 000000 2 43110081 XFR RD USR LBA B 000000000118 L 00000001 BO 24000234 BES 00ADD40.00AE15F.00ADD40
61978 742 283 02 011101 000000 2 43110081 XFR RD USR LBA B 00000000011C L 0000006C BO 24000E74 VL CEBB.0C40
Replacing heads makes sense for data recovery.
You said that the data was copied and only repairs are needed.
PostPosted: February 25th, 2023, 4:28
To remove busy, just change the high byte of PerformanceFlags in the terminal.
And by control R in the terminal, bring it to readiness via SATA.
No power switch. On power-up, the DISABLE_IDLE_ACTIVITY bit will be set to zero.
Changing other parameters is only needed for data recovery. To repair will only interfere with the analysis.
PostPosted: February 25th, 2023, 11:18
Only "sensible" was copied, there's a lot of not vital files not copied due to lack of space on backup drive (I know it sound strange nowadays for only 1TB but that is).
Ok, so as first step I'll try to restore SATA activity following your istructions, if it works I will launch seagatetools (or a better one if you can tell) to collect more informations.
thanks
PostPosted: February 26th, 2023, 5:28
After all, you need data.
Then it's not for me.
PostPosted: February 27th, 2023, 4:06
Data is not important, the hdd it self even less. I want to know what gone wrong whit it and try to restore. I'm prepared to fail. If that premises are not in the spirit of this forum please let me know and suggest a more appropriate one.
I set to 1 the DISABLE_IDLE_ACTIVITY and reboot the PC, no effect
I set all others flags (excluding media cache) as suggested by fzabkar, no effect
in the mean time I downloaded with YModem files 093 1B 346 and few others, just in case.
One aspect that I should mention: when I connect the SATA data connector the PC boot is very slow (the BIOS splash screen stands for long time), and when I hit CTRL+Z it takes about one minute to show the F3 prompt
I hope this could give a further clue
Users browsing this forum: Bing [Bot], Google [Bot] and 240 guests
