 Post subject: Seagate BarraCuda Platter Filling Order
PostPosted: April 16th, 2023, 6:43
Does anyone know the order in which the platters of a Seagate BarraCuda ST3000DM007 are filled in Windows, assuming a single maximum partition? Also, are they filled from inside to outside?
 Post subject: Re: Seagate BarraCuda Platter Filling Order
PostPosted: April 16th, 2023, 7:38
Why not just tell us what the second dr lab have told you, on track wasn't it.
PostPosted: April 16th, 2023, 8:22
I've updated the thread.
I'm asking the question because it is only the most recently saved files that I need from the patient drive, and if there's a chance that those are all going to a platter that wasn't damaged, then it might be worth sending it somewhere else for one more evaluation.
PostPosted: April 16th, 2023, 13:31
The drive writes 100 tracks, say, on head 0, then switches to head 1 and writes 100 more tracks, then 100 tracks on head 2, and back to head 0 for the next 100 tracks, and so on.
This "serpentine" tracking is described here:
https://hddscan.com/doc/HDD_Tracks_and_Zones.html
PostPosted: April 17th, 2023, 2:08
Thanks fzabkar for this important post.
I would like to know more about how selectively heads write like -
1) At start which head out of many reads SA and firmware - If it is damaged then what
2) After how many tracks head switches - if it is 100 tracks for 10TB disk then heads will be violently change so fast they might wear out fast.
3) Any video showing hows heads and platters are synchronised -how single file is divided across many platters and how different heads read same file.
This will be helpful in situations where I blindly disable heads in DE so files covered by disabled heads get corrupted due to missing sectors. I can better update customers as how this mechanisam works :-D :good:
Thanks aagain
PostPosted: April 17th, 2023, 8:03
Seagate Grenada headmaps can be all over the place. I've seen some where one head starts with 1 or 2 random sectors in before switching , while other heads have hundreds or thousands. Then there are the cases where the start sector isn't even head 0.
At the end of the day, each case is different and the only way to know if the required file is recoverable is to get the drive reading enough to image the good surfaces and hope that you can also get lucky and get enough of the file table to even know where the files are stored.
I find such cases only useful when customers are just looking for photos.
PostPosted: April 17th, 2023, 12:15
On Seagate drives SA is on logical heads 0 and 1, and sometimes (rarely) on logical H2 (but not on Barracuda drives).
"Logical head" is important here, if a Seagate drive has the very bottom head present (which is physical H0) then very likely the number(index) of physical and logical heads are the same, otherwise you need to keep in mind that physical and logical head number might not be the same
it really depends on the drive, if you can give us full model number and the PN then some of us here might be able to be more specific
the files are written by the file system driver, and the file system driver has no clue about where in the drive it writes, it has no idea that the drive has heads and how many, or any clue about the serpentine writing, so there is no relation between a file and a physical head.
However, linear file writing will in general follow the serpentine file writing on most of the Seagate drives
PostPosted: April 19th, 2023, 2:37
Finally last words have came from world's most authoritative person for Seagate Drives ( I am wondering whether seagate might not be knowing many secrets / flaws which Doomer , pepe and others including fzabkar know)
Appreciate your technical skills ,dedication and focus.
Thanks for sharing this information.
I was absolutely not aware following -
1) Physical and logical heads are different. I get this option in UDMA which heads to select often I select physical Don't know whether it is right or wrong.
2) Head 0 numbering starts with bottom platter.
3) If any seagate drive has bottom head then both logical and physical heads are same
I still dont know difference between physical and logical heads as all I know that disk has read write heads physically present.
In udma I always disable some heads if they give lots of bad sectors or reading errors.Let me confess I grossly ignore root cause of errors which might be in FW or defect list etc.
Thanks again :good: :-D
PostPosted: April 19th, 2023, 11:48
Physical heads are the heads that are physically present on the HSA.
Logical heads always starts from 0 and and are always consecutive. The drive uses logical heads to read any data from tracks.
for example
PH LH
0 -> 0
1 -> 1
2 -> 2
3 -> 3
or
PH LH
1 -> 0
3 -> 1
4 -> 2
5 -> 3
PostPosted: April 20th, 2023, 0:05
for example
PH LH
0 -> 0
1 -> 1
2 -> 2
3 -> 3
or
PH LH
1 -> 0
3 -> 1
4 -> 2
5 -> 3
Thanks .But I haven't understood anything yet.I will dig deeper.
PostPosted: April 20th, 2023, 0:08
Spildit wrote:
Thanks Spildit
I haven't seen so comprehensive and well compiled post .It has covered everything. It will take lots of time for me to digest this. I have just downloaded hddoracle for offline browsing .Its sort of HDD wikipidia. :good: :-D
PostPosted: April 21st, 2023, 6:21
for example
PH LH
0 -> 0
1 -> 1
2 -> 2
3 -> 3
or
PH LH
1 -> 0
3 -> 1
4 -> 2
5 -> 3
@terminator2
On drives with no missing/deactivated heads, as on the 4 heads drive example above 0,1, 2, 3, the physical heads map will be consecutive from the bottom: Head 0, Head 1, Head 2 and Head 3. Therefore, the software tool (Data Extractor) will create a logical map that will match the physical heads map exactly.
On drives that have missing/deactivated heads, using the physical head map example above of 1,3,4,5, it means head 0 and head 2 are physically missing/deactivated. As a result, Data Extractor won't reflect those missing heads, so in the logical map, the heads will be shifted. So, logical head 0 will be the first logical head, matching physical head 1, as that is the first active physical head. And so on.
It would be nice if Data Extractor could VISUALLY match the logical map to the physical map exactly even with those odd maps, but they are not programmed that way. Not sure if it is even possible, as programming is not my strength.
PostPosted: April 21st, 2023, 23:12
labtech wrote:
for example
PH LH
0 -> 0
1 -> 1
2 -> 2
3 -> 3
or
PH LH
1 -> 0
3 -> 1
4 -> 2
5 -> 3
@terminator2
Nicely explained and well understood. Thanks a lot :good: :-D
I would like to know which heads (physical or logical) to select in DE when it asks for selection. Will that matter in results ?
PostPosted: April 21st, 2023, 23:19
labtech wrote:
for example
PH LH
0 -> 0
1 -> 1
2 -> 2
3 -> 3
or
PH LH
1 -> 0
3 -> 1
4 -> 2
5 -> 3
@terminator2
Thanks .Is that Means for normal hard disks (non deactivated disks) Physical Heads should be selected in DE and for missing deactivated cases logical heads ?
PostPosted: April 25th, 2023, 19:51
Please, could you show a photo of this window asking you to select physical or logical? I think you are probably referring to something else, not building a heads map.
PostPosted: April 26th, 2023, 10:23
Oh yes labtech. I also feel so. I will update snapshot of the window which I am referring to.
Users browsing this forum: No registered users and 214 guests
