 Post subject: Mac Pro HDD with known password . How to recover
PostPosted: May 30th, 2023, 9:01
I have a case. User did encrypt data with password on Mac own encryption tool. But now there is no pop up window that asking password
I never used Mac. Any advice to work in Windows.. Or easy way on Mac
Password protection apllied with this way customer said
https://www.youtube.com/watch?v=taTeDKszkN8
Sexy Womans from your town
 Post subject: Re: Mac Pro HDD with known password . How to recover
PostPosted: May 30th, 2023, 11:20
Assuming you have a good image - it should be recognised as encrypted in any of the usual applications (ufs-explorer or r-studio) or even DE, all are platform agnostic. You'll need the password though.
PostPosted: June 4th, 2023, 5:10
I am trying on clone not image.(No bad sector. ) That programs not recognised as encrypted. I have password.
PostPosted: June 7th, 2023, 11:02
I also never used Mac. But are we talking about the boot disk of this Mac or just an external disk?
Anyway, if I understand the way in the video correctly, it cannot encrypt already existing data and will wipe the whole partition/disk before it will be encrypted and mounted. Then and only then it is ready to receive data. If this video-tutorial was followed carelessly and clicked through ...data is gone and you have an empty image.
Can you give more details:
-Which MacOS version exactly? Sierra...Catalina vXX?
-Is it only one partition or three?
Example for three
Number  Start (sector)    End (sector)  Size       Code  Name
   1              40          409639   200.0 MiB   EF00  EFI System Partition
   2          409640      1953262983   931.2 GiB   AF05
   3      1953262984      1953525127   128.0 MiB   AB00  Booter
-MBR or GUID?
-HFS+ encrypted or APFS encrypted?
Maybe this helps: https://support.apple.com/guide/securit ... ee0835/web
Also possible that the encryption is bound to that specific Mac-device, but that's only a guess...
PostPosted: June 17th, 2023, 6:31
Anyway, if I understand the way in the video correctly, it cannot encrypt already existing data and will wipe the whole partition/disk before it will be encrypted and mounted. (After than user used drive. everytime see pop up pasword window. but not now) Then and only then it is ready to receive data. If this video-tutorial was followed carelessly and clicked through ...data is gone and you have an empty image.
-Is it only one partition or three?yes
Example for three
-MBR or GUID?
PostPosted: June 17th, 2023, 12:21
If it's an external WD myboo HDD with filevault enable, you need to use orignial USB/SATA bridge that was on the drive. If you connect SATA directly, it won't work.
Users browsing this forum: Google [Bot] and 102 guests
