 Post subject: WD WD20SDRW Encryption
PostPosted: May 18th, 2023, 12:37
Hi
I have this usb drive with many bad sectors, so I changed PCB to 800065 Sata with an unlocked rom with PC3K
but now all sectors are encrypted, what should I do? how to decrypt?
https://filebin.net/4pbclpym5tuvzbv7/Modules_ByI.rar
 Post subject: Re: WD WD20SDRW Encryption
PostPosted: May 18th, 2023, 12:43
You need to use the original pcb to decrypt. Make your changes to the rom and write it back to the usb board or convert the usb to sata.
PostPosted: May 18th, 2023, 12:53
In all WD20SDRW cases should use original PCB ? so absolutely no Use of PCB 800065 for data recovery?
PostPosted: May 20th, 2023, 3:38
Could anyone confirm this for me?
PostPosted: May 20th, 2023, 4:06
https://www.recoveryforce.com/forums/vi ... .php?t=508
If your data wasn't encrypted before the swap and "now all sectors are encrypted" then the pcb is the first place to start. If your data has always been encrypted then that's going to be a different problem.
PostPosted: May 20th, 2023, 4:41
Okay, thanks, any tutorial or pictures showing convert 800067 to Sata ?
PostPosted: May 22nd, 2023, 11:12
Ace labs have a blog:
https://blog.acelab.eu.com/pc-3000-hdd- ... drive.html
You can buy these (doesn't have to be from Dolphin, checkout Aliexpress)
Clip on POGO adapter for converting USB to Sata
https://www.youtube.com/watch?v=9ciRpZj ... hinDataLab
Or
https://www.hddheadtools.com/product/hd ... g-pcb-pro/
PostPosted: May 23rd, 2023, 2:19
Hi ,
please contact me , I have a lot of client from IRAN
Jieshan Weng
Skype:jieshan.weng
Ph(whatsapp):+8613764461998
https://www.facebook.com/datarecoveryChina
http://www.datarecovery-china.com
Users browsing this forum: No registered users and 277 guests
