 Post subject: ST2000LM007-1R8174 EB01 Head 0 Error
PostPosted: May 27th, 2023, 8:33
HDD ST2000LM007-1R8174 EB01 comes with the H0 Err after Unlocking by MRT
Boot 0x80M
TCC:0027
[LBA=0x00000001][LBA=0x00000001]
DSC PASS
SIM FileFD=FC000000 ErrorCode=43160080 DiscLBA=0000000000000001 Duration=00000189 ms[LBA=0x00000406][LBA=0x00000406]
SIM FileFD=FC00320D ErrorCode=43160080 DiscLBA=0000000000000406 Duration=00000046 ms
---Mrt UnLock---
LockCode:0xC291B792
LockKey:
Rst 0x80M
T:0x001B 0x10036900
FTU
TCC:0027:0031 EMCDataErr:00000012
SIM FileFD=FC000000 ErrorCode=43160080 DiscLBA=0000000000000001 Duration=00000489 ms
SIM FileFD=FC38314E ErrorCode=43160080 DiscLBA=000000000000B447 Duration=00000484 ms
SIM FileFD=FC39B1D2 ErrorCode=43160080 DiscLBA=00000000000091DD Duration=00000489 ms
DSC PASS
SIM FileFD=FC3981D1 ErrorCode=43160080 DiscLBA=000000000000920F Duration=00000484 ms
SIM FileFD=FC357019 ErrorCode=43160080 DiscLBA=00000000000058E5 Duration=0000047E ms
SIM FileFD=FC35801A ErrorCode=43160080 DiscLBA=0000000000004F71 Duration=00000484 ms
SIM FileFD=FC35D01E ErrorCode=43160080 DiscLBA=000000000000554F Duration=0000047E ms
SIM FileFD=FC366301 ErrorCode=43160080 DiscLBA=000000000000B43C Duration=00000484 ms
SIM FileFD=FC379132 ErrorCode=43160080 DiscLBA=000000000000A04E Duration=00000479 ms
SIM FileFD=FC379132 ErrorCode=43160080 DiscLBA=000000000000A04F Duration=00000489 ms
PrgF
PrgF
SIM FileFD=FC3B4071 ErrorCode=43160080 DiscLBA=0000000000005EA5 Duration=0000047C ms
SIM FileFD=FC376115 ErrorCode=43160080 DiscLBA=000000000000B438 Duration=0000047E ms
SIM FileFD=FC3A721B ErrorCode=43160080 DiscLBA=000000000000C34A Duration=0000047E ms
SIM FileFD=FC360028 ErrorCode=43160080 DiscLBA=00000000000058E7 Duration=0000047D ms
SIM FileFD=FC38630A ErrorCode=43160080 DiscLBA=0000000000008F9E Duration=00000484 ms
SIM FileFD=FC37A093 ErrorCode=43160080 DiscLBA=0000000000008F9F Duration=0000047F ms
SavedReadyStatus: 0x00000005
(P) SATA Reset
RAW OFF
SIM FileFD=FC3A217A ErrorCode=43160080 DiscLBA=000000000000BBB3 Duration=0000047E ms
SIM FileFD=FC3B217B ErrorCode=43160080 DiscLBA=000000000000BBD4 Duration=00000483 ms PASS
SIM FileFD=FC37D134 ErrorCode=43160080 DiscLBA=000000000000BBD6 Duration=00000484 ms
SIM FileFD=FC37D134 ErrorCode=43160080 DiscLBA=000000000000BBD6 Duration=00000479 ms
Drive AMPS Configuration has been modified from compiled defaults.
Drive must be re-initialized to controller firmware defaults by re-downloading controller firmware
DO NOT SHIP WITHOUT FIRST RE-DOWNLOADING CONTROLLER FIRMWARE OR RESETTING TO DEFAULTS!
SIM Error 3005 LBA 000000000001699F FD FC37A093
RW Error 00000080
SIM FileFD=FC37E135 ErrorCode=43160080 DiscLBA=000000000000BBB5 Duration=00000479 ms
SIM FileFD=FC3B51EB ErrorCode=43160080 DiscLBA=000000000000C755 Duration=0000047E ms
SIM FileFD=FC30121E ErrorCode=43160080 DiscLBA=0000000000036800 Duration=00000479 ms
SIM FileFD=FC3B7181 ErrorCode=43160080 DiscLBA=000000000000CE58 Duration=0000048A ms
SIM FileFD=FC3981D1 ErrorCode=43160080 DiscLBA=000000000000920F Duration=00000479 ms
SIM FileFD=FC3971D0 ErrorCode=43160080 DiscLBA=0000000000008FA1 Duration=00000489 ms
6Gb Max Speed lowered to 3Gb for Intel bug
Send Status: COMRESET seen
CSpd= 1.5Gbps
FIS34
SIM FileFD=FC399199 ErrorCode=43160080 DiscLBA=0000000000009B08 Duration=0000047A ms
DOS:0 Scan Unit
ASCII Diag mode
From the Above Errors I changed HM to 01 01 02 03. After changing this head map getting the Same Errs as above
I can read all System Files from H1 without any Err. Then I I tried to read Copy 0 got Err
I tried to write copy 1 sys files to copy 0, all goes well. After restart getting the Same Errs So H0 has can't read but can Write.
Why when headmap changed to 01 01 02 03 it tries to read Err from H0 ?
 Post subject: Re: ST2000LM007-1R8174 EB01 Head 0 Error
PostPosted: May 27th, 2023, 12:14
Here attached Original ROM
ROM-Original.rar [271.93 KiB]
Downloaded 272 times
PostPosted: May 27th, 2023, 16:02
if you change hm to 1123, nothing gets written to nor read from H0. If you write, you likely overwrite something on side 1 with wrong data. Any read attempt from H0 will result in an error coz drive will try to read it from H1, which will obvously fail.
Moreover there's a good chance that a head/surface damage will stay unnoticed until the surface damage is serious enough to make problems on reading other surfaces.
So these head map changes must be used very carefully, i had a lot of drives that others tried to recover by changing head map and finally resulting in serious surface damages. Yeah, it's a few clicks but easy to set up for a disaster :s
PostPosted: May 28th, 2023, 0:39
After Changing HM to 1123 I can access UA sectors with very very slow as well as red and yellow blocks equally with Green.
My question is after changing HM to 1123 I can read sector 0 with Sector Viewer it is 55 AA as well as Last Sector . how it is? if H0 is blocked then sector 0 will not be accessed usually( From My Previous Experience)
IN DE HM creation shows sector 0 belongs to H0.
If anything wrong in my assumption pls clarify
