 Post subject: Head compatibility -ST750LM022 firmware 2AR20003 vs 2AR20002
PostPosted: July 9th, 2023, 20:14
Hi all.
Long time no post.
I have a Samsung ST750LM022 that I suspect has a faulty head and/or platter damage.
I assume it has two 500gb platters with 3 operational heads.
I have two donor drives.
I'm not too sure if these drives have compatible heads.
The customer's drive has firmware 2AR20003 Rev.A.
The HDD P/N is HN-M750MBB/D1.
The donor drives both have firmware 2AR20002 Rev.A
The HDD P/N for both is HN-M750MBB/AS1.
Would these be suitable donors?
Thanks in advance for any advice you can provide.
 Post subject: Re: Head compatibility -ST750LM022 firmware 2AR20003 vs 2AR2
PostPosted: July 10th, 2023, 1:39
Check ROM for headmap and pre-amp. FW version don't tell anything about compatibility.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: July 12th, 2023, 2:36
Exactly so.
Users browsing this forum: No registered users and 35 guests
