 Post subject: WDC External USB - WDC WD10SDZW-11UMGS0
PostPosted: July 5th, 2023, 7:47
does anyone have a database what palmer drives are using CPU encryption ,I have a WDC WD10SDZW-11UMGS0 does anyone know if these are cpu encrypted ,Its a stupid question but i have a case were i feel data recovery guy has used a sata board and formatted hdd and done what not that i can imagine
 Post subject: Re: WDC External USB - WDC WD10SDZW-11UMGS0
PostPosted: July 6th, 2023, 0:11
This drive uses MCU encryption
WD10SDRW-11A0XS0-01.01A01-WD-WXL2A81JZZV0-000500AP
Check Module 127.rpm
PostPosted: July 6th, 2023, 12:54
GPS ,
i will check this in the morning and revert back ,If its encryption then its mcu based right ,Then PBA access method for this will not work at all
PostPosted: July 8th, 2023, 4:20
Bump,
GPS All Modules 0123 ~ 0127 are like your second image ,So does that mean this is a MCU encryption based HDD from WDC ?
PostPosted: July 9th, 2023, 10:25
Amarbir[CDR-Labs] wrote:
Bump,
Yes
PostPosted: July 9th, 2023, 10:50
Bump,
Yes
Well,
SED Was enabled in Mod 02 so when i used to connect this to a usb board it showed file system ,Every sector was zero ,Then if i used sata board sed was still enabled but it showed exactly the same stuff ,How is that possible ,The only thing i can understand is that data recovery guy has installed sata board and formatted hdd ,HDD is 2018 model ,Encryp was not used those time ,why do i get all these lousy cases damn
PostPosted: August 1st, 2023, 5:17
Amarbir,
I've literally just got the same one in. 2018 Jun - My Passport 1TB WD with WDC WD10SDZW-11UMGS0
I've popped on my Unlock PCB to work on firmware.
SED is on.
I went to check a sector, and the sectors are not encrypted using my non native MCU unlock board which is weird. I was just about to screw back on USB PCB but in the end I didn't need to.
How strange!
Users browsing this forum: Raphael93 and 229 guests
