 Post subject: Barracuda 7200 rpm, 500gb: what noise is this?
PostPosted: August 20th, 2023, 4:15
can anyone help identifying the problem of my hard drive based on the sound it makes?
the hhd is a Barracuda 7200 rpm, 500gb
link to video:
https://photos.google.com/share/AF1QipMaM-PDFH5Ysq5p8zRY0hsohPRG0Wv81416445KWxfHzllDNAM8CrqaRVzBoj8nPw?key=VE55di0yMVdGdE91a2FPdnFPSEJlbGZIdU0tVV9R
I have already:
1- connected the hard drive internally to a pc to rule out PCB problems
2- have opened the drive to check if it was a stuck head. The head was not in the start position but did not seem stuck. I moved the head to the start position but to no effect.
Thank you for any suggestion.
 Post subject: Re: Barracuda 7200 rpm, 500gb: what noise is this?
PostPosted: August 21st, 2023, 9:08
Motor is seized. Common Failure of those Drives.
Give it to a DR-Company when the Data is critical. It was a big Fail to open the Drive by yourself, so it will be a way more expensive.
PostPosted: August 21st, 2023, 13:32
Lol ,
Oh Yeah According to you which is the start position ,The outer egde right and it was in the inside zone right
PostPosted: August 23rd, 2023, 2:57
Data is not critical but important nevertheless. Not sure worth thousands euros. Therefore I am taking a diy approach.
But thanks for the hint on where the fail can be.
PostPosted: August 23rd, 2023, 2:58
Lol ,
yes, could be that I made a wrong assumption, it was in the inside zone.
PostPosted: August 25th, 2023, 10:51
Before you opened it under non-cleanroom-conditions and scratching the surface by moving the hsa with your bare-hand, it would have been only a few hundred euros.
Every step you will made by yourself now, brings you near to the total loss of the data. Then even a data-recovery-company can help you anymore (just saying).
Users browsing this forum: No registered users and 35 guests
