 Post subject: Seagate ST12000NM001G
PostPosted: September 5th, 2023, 3:50
Hello, i have 2 hdd of this model with the same fail in ROM, is strange.
I can read ROM, but i have the message:
WARNING!
ROM image contains crytical damaged objects
[RAP]
And is in both hdds....
This is all information about the ROM:
Servo-Symbol table is not found!
FLASH ROM Info
Image size............... : 2097152
QNR Revisions:
Flash ROM image.......... : 7
GLOB_FLASH_DIR........... : 7
BOOTFW_CONT_0............ : 0
GLOB_FLASH_DIR........... : 6
BOOTFW_CONT_1............ : 0
CAP
Validation Key........... : 0x00000020
Fam ID................... : 0xBC (Fam_BC)
Fam Member............... : 0xF
Head count............... : 16
Date..................... : 12 ene. 2020
SN....................... : ZL21ZWGJ
PCB SN................... : 0000C008KDS1
PCB PN................... : 100833704
WWN...................... : 5000C500C40CAA52
MDL1..................... : ST14000NM001G-2KJ103
MDL2..................... : ST14000NM001G
Capacity................. : 27344764928
RAP
SAP
Addr..................... : 0x00000000
Fam ID................... : 0x0 (F3 Arch (common))
Fam Member............... : 0x0
Servo FW rev code........ : 0x94D2
IAP
ID, code................................ : 0x0C5E (PUIS ID data)
ID, Model............................... : ST14000NM001G-2KJ103
ID, SN.................................. : ZL21ZWGJ
ID, WWN................................. : 5000C500C40CAA52
ID, FW.................................. : SN02
PUIS.................................... : OFF
Active config........................... : 8D40BAC5
NAND ROM cache flag, Kahuna like........ : FFFFFFFF
NAND ROM cache flag, Rosewood like...... : FFFFFFFF
CODE info
Someone can help me?
Thanks!
P.D.: i think both hdd were before in other recovery data service.
 Post subject: Re: Seagate ST12000NM001G
PostPosted: September 6th, 2023, 7:13
You are either only reading 1/2 the ROM or someone else did and wrote it back, losing the 2nd half.
PostPosted: September 6th, 2023, 8:34
It's actually neither.
This model has two ROM chips.
And the second chip has RAP in it.
PostPosted: September 6th, 2023, 10:56
Interesting. I haven't encountered this model yet. Who would have guessed?
PostPosted: September 6th, 2023, 13:30
This is a 14TB drive, but the title of your thread says 12TB.
