 Post subject: WD40EZAZ what is this noise
PostPosted: September 5th, 2023, 15:42
Hi there!
I bought this hard drive in may, it started making a clicking(beeping) sound while copying.
I try in another PC, the problem is same. It didn't fall, it wasn't knocked.
I don't know how good the video is, but that's what it does:
Spin up, quite head moving noise, beep, beep, spin down, then again.
Here is the video:
https://www.youtube.com/watch?v=WbT-Y2eUrJ4
Thank you anything help!
 Post subject: Re: WD40EZAZ what is this noise
PostPosted: September 5th, 2023, 17:26
That doesn't seem right at all. Seems like power failure.
I would send it back since it's under warranty.
ACELab partner
PostPosted: September 5th, 2023, 23:28
Yes, but my data will be lost. If it's just a panel fault, I'd try to replace it with one of the same type. If it's a mechanical error, I won't try.
PostPosted: September 6th, 2023, 3:28
Try with a better PSU, maybe it could help.
Just replace PCB will not work. You need to swap ROM too and that if not well done, might void your warranty!
ACELab partner
PostPosted: September 6th, 2023, 3:40
I tried in another pc, and with external usb case.
If the panel is faulty and the replacement solves it, then my data is more important than the warranty.
PostPosted: September 6th, 2023, 5:32
Hello, this is likely a Firmware problem (2nd level translator) with some surface damage, not PCB related.
It requires somebody who has the gear and knows what to do with it. 'No user serviceable parts inside...'
PostPosted: September 18th, 2023, 12:49
Totally agree. Thats a VeniceR Family SMR Drive. Very strange behavior of those. Got them a lot recently.
PostPosted: September 19th, 2023, 11:52
Thanks for everybody!
Users browsing this forum: No registered users and 50 guests
