 Post subject: ROM IC has failure
PostPosted: September 8th, 2023, 5:01
Hi all,
I am involved with a toshiba hdd which does not spin up
I changed its pcb with another same model (the ROM was swapped also)
now the patient PCB with DONOR ROM is ok on Donor drive , but the DONOR PCB and Patient ROM on it is faulty and the patient drive still spins not .
now what should I do to repair the ROM IC then recovering the User's data ???
Thanks in advance
 Post subject: Re: ROM IC has failure
PostPosted: September 8th, 2023, 14:25
Can you upload both the donor and patient ROM dumps? I have written a tool to verify the CPs.
Users browsing this forum: No registered users and 38 guests
