 Post subject: hddscviewer pass 1 pattern
PostPosted: September 9th, 2023, 0:07
When using tools like ddrescue or hddsuperclone what is the explanation for the attached pattern after pass 1.
Doesn't seem like 1 or 2 bad heads becuase the proportions would not be right, correct?
File comment: hddscviewer project
 Post subject: Re: hddscviewer pass 1 pattern
PostPosted: September 9th, 2023, 2:15
It looks like there was a recount of the translator.
For example, this is a seagate, on which BSY(led СС) was corrected via the terminal...
PostPosted: September 9th, 2023, 9:34
The drive was clicking and not recognized.
I swapped the heads and got this pattern.
PostPosted: September 9th, 2023, 16:28
It looks like you gambled and lost.
PostPosted: September 18th, 2023, 21:00
Outstanding!
Thank you for your insightful input.
PostPosted: September 18th, 2023, 21:02
I'm not sure what a "recount of the translator" is.
But, I am curious about what type of failure could cause this read pattern?
Users browsing this forum: No registered users and 52 guests
