Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
 Post subject: HDT721010SLA360 - where a problem might be
PostPosted: October 20th, 2023, 6:23
I have HDT721010SLA360 that is not identified by computer.
I have the same( I think correct) voltages like those on the pictures below. What should I check next?
Thank you for help
 Post subject: Re: HDT721010SLA360 - where a problem might be
PostPosted: October 20th, 2023, 6:45
why do you think the problem is pcb related? Are you using the original pcb?
PostPosted: October 20th, 2023, 8:06
Yes, it is original PCB.
So, how to continue to repair the hardisk? Any idea?
Thank you
PostPosted: October 20th, 2023, 15:47
Pepe asked two things, you only answer one.
PostPosted: October 20th, 2023, 15:57
Thank you
You haven't even told us what's wrong with the drive??
PostPosted: October 20th, 2023, 16:26
The hard disk is not seen ( detected) in BIOS. So, I think the PCB maybe a culprit.
Or where else to find the problem?
Thank you for help
PostPosted: October 21st, 2023, 4:14
Does the drive spin up?
If yes, you're wasting your time dealing with the PCB.
PostPosted: October 21st, 2023, 8:47
No, the drive does not spin
PostPosted: October 21st, 2023, 9:04
Keep talking. :) Any clicking / buzzing / any sounds at all?
PostPosted: October 21st, 2023, 9:15
No sounds at all
PostPosted: October 21st, 2023, 22:56
Can you measure any activity at the spindle motor terminals during power-on?
PostPosted: October 23rd, 2023, 3:11
There are 4 traces( on the flex cable between PCB and motor). On which trace/path should I measure activity? And only during detection in BIOS should be there activity?
PostPosted: October 23rd, 2023, 5:30
right after power on. If pcb is ok, there should be activity on all four pins at least for a few seconds after powerup. You should hear some buzzing sound as well.
PostPosted: October 24th, 2023, 13:31
I checked voltages on motor terminals but there was any voltage present (neither any sound hearing ).
Is it time for PCB replacement, eventhough the core voltages are present?
Or maybe there is an ENABLE pin somewhere which is missing or......
Any further idea?
Thank you
PostPosted: October 24th, 2023, 13:39
Can you dump the contents of U5 (93C86WP) and U7 (M25P10VP)?
PostPosted: October 25th, 2023, 3:22
Yes, I can try to dump the contents. But what can I find out from the dump?
The chips use also clock signal, as I checked from the datasheet. Is it worth checking the clock first?
And when the clock should be measurable? Only during the detection time from BIOS ?
Thank you for reply
PostPosted: October 25th, 2023, 16:27
If there is a bit error in either chip, the firmware will fail a checksum test and may not spin up the drive. I know how to verify the firmware in the NVRAM (93C86).
PostPosted: October 27th, 2023, 7:55
Thank you for your reply.
I wanted to use CH341 programmer for dump of U5 (93C86WP) and U7 (M25P10VP), but not sure it is the best choice.
Can you recommend a good programmer for reading those chips?
I also find out there is about 3.3V Vcc on both U5 (93C86WP) and U7 (M25P10VP).
According to datasheet ,however, U5 (93C86WP) should have 5V as Vcc, not 3.3V.
Do you think it maybe the culprit? How to find out from where Vcc is coming to U5 (93C86WP)?
Thank you for help
PostPosted: October 27th, 2023, 13:17
93c86 uses different algo, i doubt CH341 can handle it, but i saw there are arduino skeches out there to read it.
PostPosted: October 27th, 2023, 13:23
https://www.st.com/resource/en/datasheet/m93c46-w.pdf (2.5 V to 5.5 V for M93Cx6-W)
Users browsing this forum: Google [Bot] and 78 guests
