 Post subject: Which rom programmer works with Toshiba drives.
PostPosted: October 30th, 2023, 8:51
Which programmer I should buy to copy contents of Toshiba roms. I have the cheap CH341A which seems to read the roms but won't write without errors. I have tried 2 drives...same issue. I do very few of these so I need the cheapest that will do this one-off case.
Has anyone used the CH341A successfully on these roms? I have tried various CH341 software / versions.
Any suggestions are welcomed.
 Post subject: Re: Which rom programmer works with Toshiba drives.
PostPosted: November 9th, 2023, 13:31
I have been using SOFI SP8-A for years with some of these connectors
https://www.aliexpress.com/item/3295968 ... C6sBCK0aqH
PostPosted: November 9th, 2023, 14:56
Pretty happy with Revelprog IS, just works.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: November 9th, 2023, 15:07
+1. Lots of ROM versions and easy to use.
PostPosted: November 9th, 2023, 15:44
I use Revelprog too
My firmware database:
PostPosted: November 9th, 2023, 16:52
i have xgecu t48 works fine
PostPosted: November 9th, 2023, 21:09
a terminal adapter is sufficient for most tosh families...
PostPosted: November 10th, 2023, 4:13
Wonder why terminal ROM read/write function for Toshibas is missing in out tools.
Pepe, not all of us are as clever as you :wink:
Users browsing this forum: Google [Bot] and 55 guests
