 Post subject: LED:0x000000BB FAddr:0x00004A2E in Terminal Seagate 5TB 2.5"
PostPosted: November 15th, 2023, 10:07
Hi all can some help me fix the ROM its C15 Family when i power on drive spins up normal with LED:0x000000BB FAddr:0x00004A2E
in terminal as i have pc3k with 7.2.18 ver am not able to read rom using bootcode so read rom using rom programmer when i try to import rom i get "Warning ROM Image contains critical damages objects [RAP]
Am attaching the ROM as well
ROM.rar [336.21 KiB]
Downloaded 211 times
 Post subject: Re: LED:0x000000BB FAddr:0x00004A2E in Terminal Seagate 5TB
PostPosted: November 15th, 2023, 11:00
https://www.hddoracle.com/viewtopic.php?p=22181#p22181
PostPosted: November 17th, 2023, 3:53
Hi Lardman i followed the instructions in the given page and tried to save RAP separately and used f3 explorer to recorrect crc but no luck
PostPosted: November 17th, 2023, 4:50
You need to correct the problem with it not just the CRC - when I had a quick look there were nearly 200 possibilities for bit flips alternatively just pass the rom over to Ace support to fix.
PostPosted: November 18th, 2023, 1:50
Hi i don't have technical support as well as ace cant fix it I had a previous case with just a single bit error and ace couldn't fix it and MR.fzabkar fixed it and sent me the rom ,ace technical support is not good in rom related issues.
PostPosted: November 21st, 2023, 2:05
Can somebody help me fix this rom hello MR.fzabkar can u kindly help me
Users browsing this forum: Google [Bot] and 45 guests
