 Post subject: PCB with mutiple ROMs
PostPosted: November 16th, 2023, 11:35
Drive Model: TOSHIBA MG07ACA12TE
Drive Capacity: 10TB
Hello, i have ths broken PCB and a donor. I want to replace the ROM but im not sure which i have to change.. do you guys know which one i have to change? Thank you.
 Post subject: Re: PCB with mutiple ROMs
PostPosted: November 17th, 2023, 11:28
I believe those other ROMs constitute nonvolatile cache for power loss data protection. I suspect that if you don't transfer all 4 ICs, there may be a finite risk of contaminating the patient's data with the donor's NVcache (if the NVcache is not empty).
PostPosted: November 18th, 2023, 8:02
What he said ^^^
PostPosted: November 20th, 2023, 9:03
fzabkar, Tank you for your reply! I got the Solution. I replaced the yellow marked ROM and it worked fine.
Users browsing this forum: Google [Bot] and 75 guests
