Barracuda II, how to regenerate translator?
November 27th, 2023, 15:31
Does anyone know the command to regenerate the translator on a Barracuda II?
Re: Barracuda II, how to regenerate translator?
November 27th, 2023, 17:31
I hope you won't get much of an answer until you provide more details:
Full model of the drive
Problem description
November 27th, 2023, 20:23
ST 310216A
Problem description
No access to sectors beyond a few 100k sectors
November 28th, 2023, 0:05
Are you sure? Did you do a headmap to confirm that it isn't just a bad head?
November 28th, 2023, 7:26
lcoughey wrote:Are you sure? Did you do a headmap to confirm that it isn't just a bad head?
The drive has 2 heads
It's reading from both heads up to a few 100k sectors, beyond that point cannot read a single sector
unless the density from this point on is getting higher (therfore I would have to replace the heads), I can't think of another solution
November 28th, 2023, 7:48
Just checked the map
Swithing heads is about every 1k sectors (top), so reading up to a few 100k sectors with no problem means switched heads a few 100 times (atleast)
November 28th, 2023, 9:13
There where no command for this drive when we worked. Connect the drive with terminal 9600, clear glist and smart, try reverse image.
November 29th, 2023, 11:03
Disk Solution wrote:There where no command for this drive when we worked.
Ye I've noticed a few commands resulting as an invalid entry, but there are supported commands
I find it hard to believe that cannot regen translator on this one
Disk Solution wrote:Connect the drive with terminal 9600
It supports actually up 57,600
