 Post subject: Barracuda II, how to regenerate translator?
PostPosted: November 27th, 2023, 15:31
Does anyone know the command to regenerate the translator on a Barracuda II?
 Post subject: Re: Barracuda II, how to regenerate translator?
PostPosted: November 27th, 2023, 17:31
I hope you won't get much of an answer until you provide more details:
Full model of the drive
Problem description
PostPosted: November 27th, 2023, 20:23
ST 310216A
Problem description
No access to sectors beyond a few 100k sectors
PostPosted: November 28th, 2023, 0:05
Are you sure? Did you do a headmap to confirm that it isn't just a bad head?
PostPosted: November 28th, 2023, 7:26
The drive has 2 heads
It's reading from both heads up to a few 100k sectors, beyond that point cannot read a single sector
unless the density from this point on is getting higher (therfore I would have to replace the heads), I can't think of another solution
PostPosted: November 28th, 2023, 7:48
Just checked the map
Swithing heads is about every 1k sectors (top), so reading up to a few 100k sectors with no problem means switched heads a few 100 times (atleast)
PostPosted: November 28th, 2023, 9:13
There where no command for this drive when we worked. Connect the drive with terminal 9600, clear glist and smart, try reverse image.
Data Recovery, Remote support & Training https://disksolution.com.pk/
PostPosted: November 29th, 2023, 11:03
Ye I've noticed a few commands resulting as an invalid entry, but there are supported commands
I find it hard to believe that cannot regen translator on this one
It supports actually up 57,600
Users browsing this forum: No registered users and 78 guests
