 Post subject: ROM "contains critical damaged objects" RAP
PostPosted: December 16th, 2023, 7:51
hello, anyone can help me here this 8tb is not spinning
i tried to read rom (attached) by terminal
someone said it might have CRC error or something
any advice?
rom-not_spin.rar [411.03 KiB]
Downloaded 214 times
 Post subject: Re: ROM "contains critical damaged objects" RAP
PostPosted: December 16th, 2023, 9:46
I have attached your repaired ROM.
There is a partial copy of the RAP in the Extra_Space at the end of the ROM.
RAP
0007F7E0  6D 00 D2 00 0D 20 0A 00 FC 20 E8 01 00 00 00 00
Extra_Space
0004C7E0  6D 00 D2 00 0D 20 0A 00 FC 00 E8 01 00 00 00 00
rom-not_spin_repaired.7z [368.34 KiB]
Downloaded 220 times
PostPosted: December 18th, 2023, 3:39
Am wondering the reason how it happened?
PostPosted: December 18th, 2023, 14:07
When charge leaks out of a particular cell, what happens to that bit?
PostPosted: December 19th, 2023, 3:32
thank you for your help will try and report back, how do you spot this? i try the f3_rom_explorer but not helping much or maybe i use wrong
PostPosted: December 19th, 2023, 3:38
Data in the "noise" at the end of the ROM:
https://www.hddoracle.com/viewtopic.php?p=23220#p23220
PostPosted: December 19th, 2023, 3:53
i see :wink:
