 Post subject: WD80EZAZ coming ready but errors every sector
PostPosted: December 18th, 2023, 18:09
This drive seems to initialize but has errors at every sector. Is there a firmware fix that can be done for this drive?
 Post subject: Re: WD80EZAZ coming ready but errors every sector
PostPosted: December 18th, 2023, 18:17
This drive is a native HGST model with new firmware architecture.
PostPosted: December 18th, 2023, 18:28
Is this supported by the pc3k? If so, which family is it?
PostPosted: December 18th, 2023, 18:32
Very few people know how to access and fix fw of this drive, they keep it as secret.
PC3000 doesn't support it!
My firmware database:
PostPosted: December 18th, 2023, 18:51
I think this is the corresponding HGST family (same PCB):
https://documents.westerndigital.com/content/dam/doc-library/en_us/assets/public/western-digital/product/data-center-drives/ultrastar-sata-series/product-manual-ultrastar-dc-hc510-sata-oem-spec.pdf
PostPosted: December 19th, 2023, 12:04
These drives initialize from PCB only (with correct model name and full capacity).
It is important to understand if it is actually a FW problem.
If the drive calibrates (this drive has a long and distinct calibration sound, you can't miss it) then it is likely FW problem.
If the drive does not calibrate then it's either bad heads or media damage.
For FW you can outsource it to us - https://thedigilab.com/enquiry.html
PostPosted: December 19th, 2023, 12:12
yeah it definitely calibrates
