 Post subject: Poweredge T610 HDD light not on after sg-format.
PostPosted: January 10th, 2024, 10:09
I bought 8 2tb drives off eBay, they had type 2 protection on them so I sg_format -v -F /dev/sdX and removed the protection on all the drives.
They all show up in Proxmox and I can make a ZFS pool and write to the pool without any issues.
During the sg-format of /dev/sdd, the power blinked out for a second. The T610 was on my bench top while I setup the machine and was not on battery backup. :(
After booting the machine back up, the HDD light for that drive will blink on during self test and when read/write ops are happening but it will not stay on when idle like the other 7 drives.
Everything else seems ok. Should I keep investigating or just ignore it.
This is the drive in question, /dev/sdd.
Below this code block is another drive from the 8 I bought that is working properly, /dev/sde
root@pve:~# smartctl -x /dev/sdd
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.131-2-pve] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Vendor:               IBM-D050
Product:              ST2000NX0263
Revision:             BD4D
Compliance:           SPC-4
User Capacity:        2,000,398,934,016 bytes [2.00 TB]
Logical block size:   4096 bytes
LU is fully provisioned
Rotation Rate:        7200 rpm
Form Factor:          2.5 inches
Logical Unit id:      0x5000c500b860642f
Serial number:        W461BTAD0000E841JMR9
Device type:          disk
Transport protocol:   SAS (SPL-3)
Local Time is:        Wed Jan 10 07:36:59 2024 EST
SMART support is:     Available - device has SMART capability.
SMART support is:     Enabled
Temperature Warning:  Enabled
Read Cache is:        Enabled
Writeback Cache is:   Disabled
=== START OF READ SMART DATA SECTION ===
SMART Health Status: OK
Grown defects during certification = 0
Total blocks reassigned during format = 0
Total new blocks reassigned = 0
Power on minutes since format = 833
Current Drive Temperature:     35 C
Drive Trip Temperature:        65 C
Elements in grown defect list: 0
Error counter log:
           Errors Corrected by           Total   Correction Gigabytes    Total
               ECC          rereads/    errors   algorithm processed    uncorrected
           fast | delayed   rewrites  corrected  invocations   [10^9 bytes]  errors
read:   2851836772        0         0  2851836772          0 291215.743           0
write:         0        0         0         0          0 143605.909           0
verify: 1928732332        0         0  1928732332          0 2215.588           0
Non-medium error count:      608
SMART Self-test log
Num  Test              Status                 segment  LifeTime LBA_first_err [SK ASC ASQ]
     Description                              number   (hours)
# 1  Background short  Completed                   - 0                 - [-   -    -]
Long (extended) Self-test duration: 20400 seconds [340.0 minutes]
Background scan results log
  Status: waiting until BMS interval timer expires
    Accumulated power on time, hours:minutes 34689:44 [2081384 minutes]
    Number of background scans performed: 216,  scan progress: 0.00%
    Number of background medium scans performed: 216
Protocol Specific port log page for SAS SSP
relative target port id = 1
  generation code = 0
  number of phys = 1
  phy identifier = 0
    attached device type: SAS or SATA device
    attached reason: unknown
    reason: unknown
    negotiated logical link rate: phy enabled; 6 Gbps
    attached initiator port: ssp=1 stp=1 smp=1
    attached target port: ssp=0 stp=0 smp=0
    SAS address = 0x5000c500b860642d
    attached SAS address = 0x5d4ae520ac07d993
    attached phy identifier = 1
    Invalid DWORD count = 8
    Running disparity error count = 8
    Loss of DWORD synchronization = 11
    Phy reset problem = 0
    Phy event descriptors:
     Invalid word count: 8
     Running disparity error count: 8
     Loss of dword synchronization count: 11
     Phy reset problem count: 0
relative target port id = 2
  generation code = 0
  number of phys = 1
  phy identifier = 1
    attached device type: no device attached
    reason: unknown
    negotiated logical link rate: phy enabled; unknown
    attached initiator port: ssp=0 stp=0 smp=0
    SAS address = 0x5000c500b860642e
    attached SAS address = 0x0
    attached phy identifier = 0
    Invalid DWORD count = 0
    Running disparity error count = 0
    Loss of DWORD synchronization = 0
     Invalid word count: 0
     Running disparity error count: 0
     Loss of dword synchronization count: 0
root@pve:~# smartctl -x /dev/sde
Vendor:               IBM-D050
Revision:             BD4D
Compliance:           SPC-4
Logical Unit id:      0x5000c500b860581f
Serial number:        W461BS5B0000E84200DS
Device type:          disk
Local Time is:        Wed Jan 10 07:38:09 2024 EST
Power on minutes since format = 2896
Current Drive Temperature:     34 C
Error counter log:
read:   123644058        0         0  123644058          0 302089.360           0
write:         0        0         0         0          0 141515.484           0
verify: 1889425582        0         0  1889425582          0 2205.915           0
Non-medium error count:        2
SMART Self-test log
    Accumulated power on time, hours:minutes 34689:10 [2081350 minutes]
    Number of background scans performed: 215,  scan progress: 0.00%
    Number of background medium scans performed: 215
  generation code = 0
  number of phys = 1
  phy identifier = 0
    reason: unknown
    SAS address = 0x5000c500b860581d
    attached SAS address = 0x5d4ae520ac07d994
    attached phy identifier = 2
    Loss of DWORD synchronization = 2
     Loss of dword synchronization count: 2
  generation code = 0
  number of phys = 1
  phy identifier = 1
    reason: unknown
    SAS address = 0x5000c500b860581e
 Post subject: Re: Poweredge T610 HDD light not on after sg-format.
PostPosted: January 10th, 2024, 13:08
Could this be what your seeing?
SAS HDD Activity LED always on - Ready LED Meaning bit:
https://www.hddoracle.com/viewtopic.php?p=279#p279
PostPosted: January 10th, 2024, 21:05
That was exactly it. Thanks!
And for anyone else who stumbles upon this post with the same issue, here are the steps I did to get the drive light back on.
Following the instructions that user fzabkar mention above from this original post: https://www.hddoracle.com/viewtopic.php?p=279
apt install -y sdparm
sdparm --clear=RLM --save /dev/sdX
Poweroff machine to fully reset HDD
Users browsing this forum: Google [Bot] and 61 guests
