 Post subject: Operation terminated at offset 0 LBA 0
PostPosted: January 10th, 2024, 11:45
I copied 10different SSDs with Host OS to keep as backup, so in case some of them will die I will quickly deploy same OS on new SSD from image backup...
Now I tried to clone the saved image on new and larger SSD, but I get "Operation terminated at offset 0 LBA 0" error...
I tried 5 different new disks, still the same, tried different images I have from different machines, still same.
I tried to connect the disk both 1. directly on SATA cable, and 2. with USB-to-SATA converter as external disk, still the same.....
I tried to remove all partitions on disk, then clone the image no luck. I tried to put it offline, no luck....
Any ideas?....I really need to bring the dead machine back to work
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 70 guests
