 Post subject: 2,5 inch WD USB hard drive 2060-800041-003 problem
PostPosted: January 15th, 2024, 16:00
The hard drive 2060-800041-003 is not detected in windows.
The white LED shines.
When touching the drive I can also feel motor running but it stops in a moment and then no reaction at all. Only LED continues shining
Are there on PCB any test points to check voltages?
Or what to try next?
Thank you for advice.
 Post subject: Re: 2,5 inch WD USB hard drive 2060-800041-003 problem
PostPosted: January 15th, 2024, 23:41
In my exp; this is a heads issue. Drive is failing a self-check on power on.
PostPosted: January 16th, 2024, 16:35
The general rule when checking the onboard supplies is to measure the voltages at the inductors.
PostPosted: January 17th, 2024, 3:45
Thanks for replies.
@fzabkar: and are there any rules which voltages must be present , regarding hard drives?
PostPosted: January 17th, 2024, 12:03
John1 wrote:
Thanks for replies.
No.
PostPosted: January 17th, 2024, 13:42
But how to measure the voltages if you do not know which value is correct ?
PostPosted: January 17th, 2024, 15:07
Experience.
