 Post subject: WDC WD10TMVW-11ZSMS4 USB to SATA issue (2060-771761-001)
PostPosted: January 23rd, 2024, 2:48
Hdd WDC WD10TMVW-11ZSMS4 with USB PCB 2060-771761-001
ROM Size: 256KB
MRT not ID but WD Marvel tools identify model and its size with USB PCB
I can save modules which are in RAM (Static files ) but can't read any modules from Platters getting "SCSI error 00000000".
so tried in SATA PCB
2060-771692-005 ( 512KB) and 2060-771692-005 (256KB) both clicks and spin down.
also tried 2060-771692-006 that also click and spin down
By USB PCB no clicks and Head reads some imp modules from platter to RAM but SATA PCB clicks and spin-down.
any solution?
 Post subject: Re: WDC WD10TMVW-11ZSMS4 USB to SATA issue (2060-771761-001)
PostPosted: January 28th, 2024, 1:32
After Converting USB PCB to SATA Connection by Remove CAPS and connect SATA connector with USB Power.
Can read all sectors with only 8 bad sectors by MRT Decryption, All Data Recovered.
my question is what is the actual SATA PCB for USB PCB 2060-771761-001 (256KB ROM)
I tried 2060-771692-005 (512KB and 256KB) and 2060-771692-006 (256KB) all Failed.
Which version of 2060-771692 is SATA PCB for 2060-771761-001 ?
Users browsing this forum: No registered users and 60 guests
