 Post subject: ST8000AS0002 ROM critical damage
PostPosted: February 16th, 2024, 10:28
Hello everyone, unfortunately, the ROM has been read and written using the wrong family by PC3000, so it was saved incomplete. I tried using a donor ROM, but it didn't work, so I attempted to merge the segments of the original ROM with the missing ones from the donor ROM using F3 Explorer. However, even in this case, the disk spins but gives an error.
Boot 0x80M
SpinUp[LBA=0x000007DA]N02020C20o0o0o0o0o0o0o0o0[LBA=0x000007DA]NO1111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01
SIM FileFD=FC00C000 ErrorCode=43110081 DiscLBA=00000000000007DA Duration=000004D7 ms[LBA=0x0001D33A]N01010C10o0o0o0o0o0o0o0o0[LBA=0x0001D33A]NO1111102010C20o0o0o0o0o0o0o0o01111102020C10o0o0o0o0o0o0o0o01111102010C10o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111102020C10o0o0o0o0o0o0o0o01111102020C10o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01
SIM FileFD=FC00C000 ErrorCode=43110081 DiscLBA=000000000001D33A Duration=000004E1 ms[LBA=0x00039E9A]N02020C20o0o0o0o0o0o0o0o0[LBA=0x00039E9A]NO1111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01
SIM FileFD=FC00C000 ErrorCode=43110081 DiscLBA=0000000000039E9A Duration=000004E1 ms[LBA=0x000012E3]N02020C20o0o0o0o0o0o0o0o0[LBA=0x000012E3]NO1111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01
SIM FileFD=FC01020D ErrorCode=43110081 DiscLBA=00000000000012E3 Duration=000004D5 ms[LBA=0x0001DE43]N01010C20o0o0o0o0o0o0o0o0[LBA=0x0001DE43]NO1111101010C10o0o0o0o0o0o0o0o01111102020C10o0o0o0o0o0o0o0o01111102020C10o0o0o0o0o0o0o0o01111102010C10o0o0o0o0o0o0o0o01111101010C20o0o0o0o0o0o0o0o01111102020C10o0o0o0o0o0o0o0o01111101010C20o0o0o0o0o0o0o0o01
SIM FileFD=FC01020D ErrorCode=43110081 DiscLBA=000000000001DE43 Duration=000004DF ms[LBA=0x0003A9A3]N02020C20o0o0o0o0o0o0o0o0[LBA=0x0003A9A3]NO1111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111101020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111101020C20o0o0o0o0o0o0o0o01111102020C10o0o0o0o0o0o0o0o01111101020C20o0o0o0o0o0o0o0o01
SIM FileFD=FC01020D ErrorCode=43110081 DiscLBA=000000000003A9A3 Duration=000004D5 ms
SimError - Remaining in BootFW
Perform a double download without a power cycle
Sending HOST FIS for engineering drives:  ReadyStatusFlags 20028100
Please, could anyone help me, if possible?
Attached incomplete ROM, assembled ROM and donor ROM.
Thanks a lot
donor_ROM.7z [277.63 KiB]
Downloaded 185 times
assembled_ROM.7z [277.22 KiB]
Downloaded 177 times
incomplete_ROM.7z [234.52 KiB]
Downloaded 176 times
 Post subject: Re: ST8000AS0002 ROM critical damage
PostPosted: February 21st, 2024, 4:50
I guess there are no solution?!
PostPosted: February 21st, 2024, 9:35
no, most of the RAP is missing, SA has no copy of it either :s
Users browsing this forum: Google [Bot] and 63 guests
