 Post subject: ST500VT000 EEPROM repair
PostPosted: March 6th, 2024, 5:18
ST500VT000
fw 0001sdc2
pn: 1dk142-502
Please help to repair this eeprom.
This hdd is not spinning. I suspect the eeprom is corrupted because if i put a different pcb it spins but no data access..Original pcb is not spining
File comment: ST500VT000
fw 0001sdc2
pn: 1dk142-502
ema hdd W25Q40BW@SOIC8-150_20240306_110927.rar [179.2 KiB]
Downloaded 497 times
 Post subject: Re: ST500VT000 EEPROM repair
PostPosted: March 6th, 2024, 9:23
this rom seems ok at first glance, what terminal output do you get?
PostPosted: March 6th, 2024, 12:23
If this drive came out of a surveillance system, perhaps it is firmware locked? (I don't see a PUIS flag in the IAP segment.)
If you can upload your donor ROM, I could transfer the patient's adaptives into it.
I presume that you have tested your patient ROM on the donor PCB and verified that the no-spin symptom moves with the ROM.
PostPosted: March 11th, 2024, 23:50
At first glance, I see that this rom version does not have too serious errors
PostPosted: March 26th, 2024, 12:48
You were right. I changed the pcb and moved the rom.. its now solved
PostPosted: March 26th, 2024, 12:49
I changed the pcb and moved the rom.. its now solved..
thanks
The pcb was dead so i moved the rom to new pcb
PostPosted: March 27th, 2024, 1:40
:cool:
Users browsing this forum: Google [Bot] and 49 guests
