 Post subject: Seagate 7e8 Exos SAS Medium is write protected
PostPosted: April 12th, 2024, 21:53
Hey guys,
I have 3 ST8000NM0065 SAS drives that I at first thought were locked. After days of googling I finally found a command that would allow me to access the drive and format it. However, In my excitement I did not save the page. :( It was on this site though.
No matter the utility I use I get the same information. No protection. Not encrypted. No password. Except the following. Medium is write protected!
Vendor ID: SEAGATE
Model Number: ST8000NM0065
Serial Number: ZA175RVC
PCBA Serial Number: 0000R731NQAU
Firmware Revision: K004
World Wide Name: 5000C50093BFD883
Date Of Manufacture: Week 19, 2017
Copyright: Copyright (c) 2017 Seagate All rights reserved
Drive Capacity (TB/TiB): 8.00/7.28
Temperature Data:
Current Temperature (C): 43
Highest Temperature (C): Not Reported
Lowest Temperature (C): Not Reported
Power On Time: Not Reported
Power On Hours: Not Reported
MaxLBA: 1953506645
Native MaxLBA: Not Reported
Logical Sector Size (B): 4096
Physical Sector Size (B): 4096
Sector Alignment: 0
Rotation Rate (RPM): 7200
Form Factor: 3.5"
Last DST information:
Not supported
Long Drive Self Test Time: 13 hours 7 minutes
Interface speed:
Port 0 (Current Port)
Max Speed (GB/s): 12.0
Negotiated Speed (Gb/s): 6.0
Port 1
Negotiated Speed (Gb/s): Not Reported
Annualized Workload Rate (TB/yr): 0.00
Total Bytes Read (GB): 584.84
Total Bytes Written (MB): 90.26
Encryption Support: Not Supported
Cache Size (MiB): Not Reported
Read Look-Ahead: Enabled
Non-Volatile Cache: Enabled
Write Cache: Disabled
SMART Status: Good
ATA Security Information: Not Supported
Firmware Download Support: Not Supported
Number of Logical Units: 1
Specifications Supported:
SPC-4
SAM-5 T10/2104-D revision 4
SAS-3 (no version claimed)
SPL-3 (no version claimed)
SPC-4 (no version claimed)
SBC-3 (no version claimed)
Features Supported:
Self Test
Automatic Write Reassignment [Enabled]
Automatic Read Reassignment [Enabled]
EPC [Enabled]
Informational Exceptions [Mode 6]
Translate Address
Rebuild Assist
Seagate In Drive Diagnostics (IDD)
Adapter Information:
Adapter Type: PCI
Vendor ID: 1000h
Product ID: 0072h
Revision: 0003h
Anyone ran across this before? I was able to fix the first one with the SeaTools USB boot drive. One of the many commands I tried removed the write protect and I was able to successfully format the drive. But as I said I was an idiot and did not make a note of the one that worked. I will continue to scour the forums to see if I can find it again.
Thanks all in advance.
 Post subject: Re: Seagate 7e8 Exos SAS Medium is write protected
PostPosted: April 24th, 2024, 22:10
484 views and not a word. :(
PostPosted: April 24th, 2024, 22:54
Maybe this?
https://www.mankier.com/8/scsi_ch_swp
https://www.mankier.com/package/sdparm
PostPosted: December 6th, 2024, 18:23
Pretty sure these drives have DIF turned on by default.. aka drive protection, write protection etc..
For these specific 4k SAS drives I'd run the following:
sudo sg_format -v -F -f 0 /dev/sdX
* This will NOT change the sector sizes . I recommend keeping 4k size although I see others have success changing
* You can run these in parallel.. e.g. start one in shell then another, format drives in parallel
* Just an FYI - an 8TB drive takes about 12 hrs to format completely
* If you close shell you lose progress.. Easy to see per drive by running:
sudo sg_format -d -v /dev/sdX
(dry run fake - but will dispaly progress per drive)
* Once complete, power down drive & system - reboot and check:
sudo fdisk -l /dev/sdX
sudo smartctl -i /dev/sdX
sudo sg_readcap /dev/sdX
Some expansion on the variables:
-v, --verbose
increase the level of verbosity, (i.e. debug output). "-vvv" gives a lot more debug output.
-f, --fmtpinfo=FPI
sets the FMTPINFO field in the FORMAT UNIT cdb to a value between 0 and 3. The default value is 0. The FMTPINFO field from SBC-3 revision 16 is a 2 bit field (bits 7 and 6 of byte 1 in the cdb). Prior to that revision it was a single bit field (bit 7 of byte 1 in the cdb) and there was an accompanying bit called RTO_REQ (bit 6 of byte 1 in the cdb). The deprecated options "--pinfo" and "--rto-req" represent the older usage. This option should be used in their place. See the PROTECTION INFORMATION section below for more information.
-F, --format
issue one of the three SCSI "format" commands. In the absence of the --preset=ID and --tape=FM options, the SCSI FORMAT UNIT command is issued. These commands will destroy all the data held on the media. This option is required to change the block size of a disk. In the absence of the --quick option, the user is given a 15 second count down to ponder the wisdom of doing this, during which time control-C (amongst other Unix commands) can be used to kill this process before it does any damage. When used three times (or more) the preliminary MODE SENSE and SELECT commands are bypassed, leaving only the initial INQUIRY and FORMAT UNIT commands. This is for emergency use (e.g. when the MODE SENSE/SELECT commands are not working) and cannot change the logical block size. See NOTES section for implementation details and EXAMPLES section for typical use.
-d, --dry-run
this option will parse the command line, do all the preparation but bypass the actual FORMAT UNIT, FORMAT WITH PRESET or FORMAT MEDIUM command. Also if the options would otherwise cause the logical block size to change, then the MODE SELECT command that would do that is also bypassed when the dry run option is given.
-e, --early
during a format operation, The default action of this utility is to poll the disk every 60 seconds (or every 10 seconds if FFMTis non-zero) to determine the progress of the format operation until it is finished. When this option is given this utility will exit "early", that is as soon as the format operation has commenced. Then the user can monitor the progress of the ongoing format operation with other utilities (e.g. sg_turs(8)or sg_requests(8)). This option and --waitare mutually exclusive.
-t, --ffmt=FFMT ( DO NOT USE!! - included as a warning for DIF removal, fast format will not work)
FFMT(fast format) is placed in a field of the same name in the FORMAT UNIT cdb. The field was introduced in SBC-4 revision 10. The default value is 0 which implies the former action which is typically to overwrite all blocks on the DEVICE. That can take a long time (e.g. with hard disks over 10 TB in size that can be days). With FFMTset that time may be reduced to minutes or less. So it is worth trying if it is available.
FFMThas values 1 and 2 for fast format with 3 being reserved currently. These two values include this description: "The device server initializes the medium ... without overwriting the medium (i.e. resources for managing medium access are initialized and the medium is not written)". The difference between 1 and 2 concerns read operations on LBAs to which no data has been written to, after the fast format. When FFMTis 1 the read operation should return "unspecified logical block data" and complete without error. When FFMTis 2 the read operation may yield check condition status with a sense key set to hardware error, medium error or command aborted. See draft SBC-4 revision 16 section 4.34 for more details.
