 Post subject: Fix Seagate 7200.14 HDD not recognized error in BIOS
PostPosted: May 27th, 2024, 23:35
I'm having problems with my Seagate 2TB ST2000DM001 Barracuda 7200.14 hard drive. The hard drive is not recognized by the BIOS even though there are no strange signs from the hard drive such as clicking sounds or irregular rotation. I tried using diagnostique commands at F3 T> prompt like V1, V3, V4, V40, N5, U, Z, X, D and got results but no SMART data is stored (all prices all values are 0 except one value which is 3). Command V40 shows "non-resident G-List" is empty.
I would like to ask if anyone has encountered a similar situation and is there any way to fix this problem? My goal is to recover data from a hard drive with an ext4 file system, not to reformat the hard drive.
 Post subject: Re: Fix Seagate 7200.14 HDD not recognized error in BIOS
PostPosted: May 28th, 2024, 12:36
HI,
Roy if Data is important then contact Data Recovery Professionals, problem could be firmware as you mention drive is not clicking and seems no physical issue Data Recovery could be done with small fee.
Good Luck......
PostPosted: May 28th, 2024, 12:47
https://forum.hddguru.com/viewtopic.php?p=310537#p310537
PostPosted: May 28th, 2024, 15:06
Why not use Ctrl X immediately after the start and exit to F3.
Well, after N5 and V40 and others.
To see the errors of reading from the SA.
Users browsing this forum: No registered users and 200 guests
