 Post subject: Short pins Seagate ST4000DM004 - 100815595
PostPosted: May 20th, 2024, 7:30
Hello. To access the terminal i need to make a short pins in this PCB, but i don't know which ones exactly.
 Post subject: Re: Short pins Seagate ST4000DM004 - 100815595
PostPosted: May 20th, 2024, 15:33
What voltages do you measure between ground and each of the 4 HDA pads when the PCB is on and off the drive?
PostPosted: May 21st, 2024, 6:11
PCB is off the drive
    A1 = 1.37V ; B1 = 0.68V
    A2 = 1.37V ; B2 = 1.02V
    A3 = 0.03V ; B3 = 3.22V
    A4 = 0.03V ; B4 = 0V
    A5 = 0V ; B5 = 1.76V
    A6 = 5.18V ; B6 = 0V
    A7 = 0V ; B7 = 0V
    ------------- ; B8 = 0V
    ------------- ; B9 = 0V
PCB is on the drive
    A1 = 1.75V ; B1 = 6.04V
    A2 = 1.75V ; B2 = 6.00V
    A3 = 0.98V ; B3 = 2.23V
    A4 = 0.98V ; B4 = 1.51V
    A7 = 2.96V ; B7 = 0V
    ------------- ; B8 = 1.76V
    ------------- ; B9 = 0.03V
PostPosted: May 21st, 2024, 10:56
The write channel would be driven by the MCU whereas the read channel would be driven by the preamp. Therefore, I believe that A3/A4 is the read channel pair (because it sits at 0.03V when the preamp is not connected).
PostPosted: June 10th, 2024, 1:26
Thanks for your reply, I'll try.
Users browsing this forum: No registered users and 257 guests
