 Post subject: RAID drive help
PostPosted: May 29th, 2024, 0:02
I'd appreciate anyone who can help, but I'm not too hopeful:
I have a raid system (Drobo) & while I was at work, I got a lot of notices about a drive having failed...not normal as the drive should have failed & have been done with it. When I got home, I realized I was the cause of the problem...I moved the RAID the day prior & started it up this morning but in the process of moving it, one drive was not fully secure. I fully secured the drive but the RAID reported the drive as fully failed. I removed it & put it in a computer to pull the smart status and found it was just fine so after a little research, I found that the RAID will record the drive's serial number internally & prevent it from being added to the unit as a precautionary measure. The drive is pretty new, the SMART report showed it good, & logs in the RAID showed that there was a lot of connections & removals today. So I have a few measures to fix this:
1) Change the serial by one digit so the RAID allows it to reconnect & determine if the disk actually failed or if it was a seating issue.
2) Factory reset the RAID, wipe all stored data (along with every drive)...not an option I want to take
3) Warranty it with the company I bought it from. If I'm right & the drive is fine...this wouldn't be ethical. There is a very small chance that the RAID did detect some other failure that SMART doesn't show so I can justify it that way...but I'd rather not.
I'd appreciate any help, but if not, I'm already looking at option number 3. Also, due to the rarity of this actually being ethical, please don't post details publicly, just send me a message if you have any ideas...I've already scoured the web & am finding the effort of option 1 is probably not worth it.
 Post subject: Re: RAID drive help
PostPosted: May 29th, 2024, 17:10
If all the drives are ok you can download a free version of this and see if it will help you rebuild. It does support Drobo raids. You will need to pull the drives and connect them to your machine.
https://www.ufsexplorer.com/ufs-explorer-raid-recovery/
something like this might help connecting them all to your PC
https://www.amazon.com/Sabrent-4-Bay-Do ... r=8-3&th=1
Of course making a disk to disk image of each drive is a good safe first start.
PostPosted: June 19th, 2024, 12:56
First, we don't know which type of RAID is your system: RAID 0, RAID 5, RAID 1, ...
All RAID can be recovered by connecting their disks individually to a computer, and reassembling the data flows (stripes) by emulating the controller logic.
My favorite tools for this: relevant softwares, some hardware, an hexadecimal editor, and ─ especially for complex cases ─ a sheet of paper and a pen.
Knowing which tools to use, how to use them, being patient and past experiences are then key factors.
I agree with user Cleanroom that UFS Explorer RAID Recovery is among the good softwares.
We also use other softwares as well on a per case basis.
Data recovery in Geneva (Switzerland)
https://www.sosdonnees.ch/en
PostPosted: June 21st, 2024, 11:07
I stumbled upon a good confusing read for a newbie like me.
https://www.sciencedirect.com/topics/co ... controller
Hope it is of help to someone.
Users browsing this forum: No registered users and 207 guests
