 Post subject: ST4000DM004 Not spinning but making mmm mmm noise
PostPosted: June 25th, 2024, 4:02
Any help??
This drive is making mmm mmmm noise that's all but not spinning!
 Post subject: Re: ST4000DM004 Not spinning but making mmm mmm noise
PostPosted: June 25th, 2024, 4:07
Most likely - blocked head on the disc surfaces.
Less likely - engine bearing damage.
Least likely - damage to the motor winding.
And once again the status of the work register and the log from the terminal after startup.
Do you have a laminar chamber?
If not, there's nothing for us here.
PostPosted: June 28th, 2024, 20:43
99% stuck head
1% motor bearing
need to open the drive in clean room and see the location of the head first
PostPosted: June 30th, 2024, 4:52
Now it's showing this
While spinning it makes a noise
Audio for your preview:
http://sndup.net/sydh5
PostPosted: July 1st, 2024, 3:38
What happened between before and "now"?
Heads are gone. Possibly media damage too.
PostPosted: July 1st, 2024, 6:36
Before it was stuck only making mmm mmm noise now when I tilt upside down the hdd spun that's all. Not intentionally but for connecting it to my lappy!
Users browsing this forum: Google [Bot] and 95 guests
