 Post subject: WD40NDZW-11BHVS1 no ID with SA access
PostPosted: July 13th, 2024, 11:18
Hey,
I got a WD40NDZW-11BHVS1 spyglass3.
I unlocked the rom chip with pc3k utility and soldered sata to the pcb, the drive comes up RDY and I have access to SA but i get “WDC-ROM SN# XYZ” ID and no sector access.
all the modules are fine except for 02, 38, 2E, 12E, 4002.
Module 02 is only corrupt at the start and I tried rewriting it to the drive from a donor but it seems like it’s on some bad sectors and I can’t write it. I don’t even know if that’s really the issue here though.
T2 seems to be fine, module190 is OK.
Attached the log running init and sa backup
Any thought?
log.log [119.29 KiB]
Downloaded 125 times
 Post subject: Re: WD40NDZW-11BHVS1 no ID with SA access
PostPosted: July 14th, 2024, 13:11
Find some unused sectors in the SA and redirect mod 02 to these sectors.
PostPosted: July 16th, 2024, 4:34
the question is wether the drive can write at all, test it on an unused space
Users browsing this forum: Google [Bot] and 70 guests
