 Post subject: wd5000aads no power
PostPosted: July 27th, 2024, 15:51
Hello
working on a wd5000aads old hard drive
was working ok, didn't used it for a while and now seem like getting no power and not detected..
i took the pcb out and connected it without the drive
i can see it has 5v rail but looks like the 12v is missing.
is there any common problem on those pcb? doesnt seem like the 12v rail is shorted to ground.
pcb number is 2060-701640-001 REV A
thanks..
 Post subject: Re: wd5000aads no power
PostPosted: July 28th, 2024, 19:14
You should use your multi meter and check the electronics. Better to post a picture of any problems you find.
Zero Alpha: zeroalpha.com.au
PostPosted: July 31st, 2024, 15:30
thanks for the answer
can you please direct me where to measure?
i should get 12v with the pcb connected without the disk?
thanks.
PostPosted: July 31st, 2024, 19:00
Are these continuous?
Users browsing this forum: No registered users and 73 guests
