 Post subject: Seagate FireCuda Gaming Hub freezing, Windows 11
PostPosted: August 5th, 2024, 3:59
I have had an 8Tb Seagate FireCuda Gaming Hub for several months which has worked fine. I recently added a different (larger) USB HDD to act as my main data storage, and to use the FireCuda as a backup drive.
However, the FireCuda now freezes whenever the desktop goes to sleep - I wake the pc and the FireCuda is unresponsive and then so is File Explorer. The only solution is to disconnect the Firecuda and reconnect.
I have tried adjusting the power settings eg
Power settings advanced:
Hard disk \ Turn off hadrd disk after : changed to Never
USB settings \ USB selective suspend setting : changed to disabled
I have removed the partition and recreated and reformatted the drive
but the problem persists. It never used to do this.
Bought from Amazon, it is outside the return window (though only 5 months so inside warranty).
Has anyone any suggestions on this?
Many thanks
 Post subject: Re: Seagate FireCuda Gaming Hub freezing, Windows 11
PostPosted: August 6th, 2024, 20:05
So many hidden annoying settings between the motherboard and windows to check. Test it on another PC. Check your Event Viewer logs for possible faults.
Zero Alpha: zeroalpha.com.au
Users browsing this forum: Majestic-12 [Bot] and 55 guests
