 Post subject: WD external HD 1TB has red arrow in the disk management
PostPosted: August 16th, 2024, 18:53
Dear Experts
I have got a WD external 1TB USB hard drive when I connect it on different computers win10 OSs and different USB ports (means tried more than one PCs with different USBs),,,,,has red arrow in the disk management
I have got data on it what should I do to recognize it without losing data ?
Thx
 Post subject: Re: WD external HD 1TB has red arrow in the disk management
PostPosted: August 16th, 2024, 19:13
Can you show us a SMART report?
https://www.reddit.com/r/datarecoverysoftware/wiki/index/smart/
PostPosted: August 16th, 2024, 19:23
For the external USB WD HD not showing as per attached snapshot
PostPosted: August 16th, 2024, 19:34
The drive looks healthy, so this could be your solution:
https://www.reddit.com/r/datarecoverysoftware/wiki/index/dmde_insert_partition_guide/
It's an in-place repair, so be aware of the risks.
PostPosted: August 16th, 2024, 19:38
It looks healthy so this could be your solution.
Are you referring to the The first option in the Disk menu ? If so it is for the internal WD hard drive not external WD
PostPosted: August 16th, 2024, 19:42
Sorry, I was confused. If CDI is not detecting the drive, then it has an internal fault.
PostPosted: August 16th, 2024, 19:45
I see
Users browsing this forum: No registered users and 61 guests
