 Post subject: WD 800069 PCB disable USB bridge
PostPosted: November 23rd, 2024, 7:46
Hello, i have this pcb where i have to unsolder the capacitors and put the adapter.
Can you indicate at the photos attached?
Thank you
 Post subject: Re: WD 800069 PCB disable USB bridge
PostPosted: November 23rd, 2024, 8:06
https://www.blizzarddr.com/convert-wd-usb-to-sata/
PostPosted: November 23rd, 2024, 13:35
thank you
PostPosted: November 23rd, 2024, 16:05
Which adapter are you intending to use?
If you have am MRT pogo pin adapter, then try this instead:
Locating the Reset* pin on USB-SATA bridge ICs:
https://www.hddoracle.com/viewtopic.php?f=59&t=3381
Users browsing this forum: Google [Bot] and 50 guests
