 Post subject: Required donor rom for ST1000VM002 1ET162-262 F/W : SC15
PostPosted: November 12th, 2024, 4:58
Hi does any 1 has donor rom for Seagate 1TB Model ST1000VM002 P/N 1ET162-262 F/W : SC15 Its Bacall Family
 Post subject: Re: Required donor rom for ST1000VM002 1ET162-262 F/W : SC15
PostPosted: November 12th, 2024, 5:35
If your ROM is corrupt, perhaps one of us could repair it? I would be willing to examine your ROM, if that is the case.
PostPosted: November 12th, 2024, 7:29
It would be great if you could fix it fzabkar sir, am attaching the rom
ROM.rar [326.07 KiB]
Downloaded 158 times
PostPosted: November 12th, 2024, 8:24
PUIS is enabled.
See https://forum.hddguru.com/viewtopic.php?p=302603#p302603
This is the Identify Device info block in your IAP segment:
-- IDENTIFY_DEVICE ---------------------------------------------------------
        0    1    2    3    4    5    6    7    8    9
  0: 0C5E 3FFF 37C8 0010 0000 0000 003F 0000 0000 0000  .^?.7........?......
10: 2020 2020 2020 2020 2020 2020 5335 3133 5357 4150              S513SWAP
20: 0000 0000 0004 5343 3135 2020 2020 5354 3130 3030  ......SC15    ST1000
30: 564D 3030 322D 3145 5431 3632 2020 2020 2020 2020  VM002-1ET162
40: 2020 2020 2020 2020 2020 2020 2020 8010 4000 2F00                ..@./.
50: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0010  @.......?....?......
60: FFFF 0FFF 0000 0407 0003 0078 0078 0078 0078 0000  ...........x.x.x.x..
70: 0000 0000 0000 0000 0000 001F 850E 0004 00CC 0000  ....................
80: 03F0 001F 346B 7D69 4133 0000 0060 4133 007F 003C  ....4k}iA3...`A3...<
90: 003C C0C0 0000 0000 8080 1000 0000 0000 2710 0000  .<..............'...
100: 6DB0 7470 0000 0000 0000 0000 6003 0000 5000 C500  m.tp........`...P...
110: 8C1B 8B51 0000 0000 0000 0000 0000 0000 0000 405E  ...Q..............@^
120: 401C 0000 0000 0000 0000 0000 0000 0000 0000 6DB0  @.................m.
130: 7470 6DB0 7470 2020 0002 0140 0100 5000 3C06 3C0A  tpm.tp  ...@..P.<.<.
140: 0000 003C 0000 0008 0000 0000 05FF 0280 0000 0000  ...<................
150: 0008 0000 0000 0000 0000 8000 0001 0000 5900 8000  ................Y...
160: 0000 0000 0000 0000 0000 0000 0000 0000 0002 0000  ....................
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
200: 0000 0000 0000 0000 0000 0000 30BB 0000 0000 4000  ............0.....@.
210: 0000 0000 0000 0000 0000 0000 0000 170C 0000 0000  ....................
220: 0000 0000 107E 0000 0000 0000 0000 0000 0000 0000  .....~..............
230: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
240: 0000 0000 0000 0003 0000 0000 0000 0000 0000 0000  ....................
250: 0000 0000 0000 0000 0000 8EA5                      ............
PostPosted: November 13th, 2024, 3:21
Thank you fzabkar its interesting, there is lot to learn from you, I will check on it and get back
PostPosted: November 13th, 2024, 7:55
PC3K can disable PUIS. Alternatively, HDAT2 can do it.
PostPosted: November 16th, 2024, 4:48
Hi fzabkar it could able to disable using HDAT2 thank you so much and drive spins and data is accessible, but strange thing is that when i connect the drive to pc3k , drive doesn't spin just curious to know why so and if pc3k can disable PUIS, if so where is the option
Users browsing this forum: No registered users and 68 guests
