 Post subject: wesern digital WD10SPZX no ID after translator regeneration
PostPosted: January 18th, 2024, 3:01
hello guys im working on this palmer disk with second sevel translator damaged.zero data 95%
i did the translator regeneration and i got zero data 18% ....however after i wrote the new 190 module and restart the hdd has no ID and no capacity.......... does anyone had same problem?
 Post subject: Re: wesern digital WD10SPZX no ID after translator regenerat
PostPosted: January 18th, 2024, 19:36
seems something else damaged
even thought mdl 190 is damaged you will still get full ID
PostPosted: January 18th, 2024, 22:36
Sir thank you for your time
i can get full ID and capacity if i write the original 190 module! but when ever i write the correct module hard disk click once and get ready without ID and without capacity!
PostPosted: January 20th, 2024, 18:13
You need to carefully repair and restore the translator.
Regenerating is almost never an option in modern SMR drives.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: January 21st, 2024, 11:35
Sir im using the new fuction of data extractor 7.0 but when i write the new translator i do not get ID and capacity
PostPosted: January 23rd, 2024, 14:45
people should not write anything to SA of these drives, you practically kill any chance for someone with proper knowledge recover the thing.
PC3k has a bug with reading 190 too, so if you write that back you (and anyone after that point) are busted .
you need to understand how these work, which is not a simple task i admit.
PostPosted: January 23rd, 2024, 21:06
i just did what is written in this page from acelab Sir.........
https://blog.acelab.eu.com/how-to-fix-t ... rsion.html
do they teach a wrong way for this drive? i dont get what part did i do wrong Sir? can you be more specific?
PostPosted: January 24th, 2024, 4:30
To me, this article should be taken down from public view.
PostPosted: January 24th, 2024, 5:21
if make the recovery worse indeed they shouldtake it down Sir
as expert can you share the correct solution Sir?
PostPosted: January 24th, 2024, 5:22
can you share your solution Sir?
PostPosted: December 6th, 2024, 13:16
I am having the same case. WD10SPZX clicks, swapped heads. Got ready but has no ID, PC3000 boots in Kernel mode
So i am curious to find the solution here
PostPosted: December 9th, 2024, 2:27
You should start your own thread instead of digging up an old one as you have a completely different problem.
Zero Alpha: zeroalpha.com.au
PostPosted: December 9th, 2024, 11:05
Thanks for the reply. I did started a new thread. Even a year ago with a different but similar case, No one responded
https://forum.hddguru.com/viewtopic.php?f=1&t=44928
https://forum.hddguru.com/viewtopic.php?f=11&t=43881
Users browsing this forum: Google [Bot] and 331 guests
