 Post subject: New Seagate Ironwolf 4TB drives with high RAW read rate
PostPosted: March 11th, 2025, 21:16
I have just purchased 2 x Ironwolf drives from Amazon direct and am running a surface scan with Victoria HD 5.37. One has finished and I have started the second, takes about 7 hours odd. I have shown the SMART pictures to Grok3 which has said the high Raw read rate maybe a cause for concern on new drives and I should contact Seagate for clarification. Before I do this and look silly I would like to flail myself to this forum for opinions on these 2 new drives and the read rate.
See attached pics.
Thoughts? :D
 Post subject: Re: New Seagate Ironwolf 4TB drives with high RAW read rate
PostPosted: March 11th, 2025, 22:17
https://www.hddoracle.com/viewtopic.php?p=158#p158
http://t1.daumcdn.net/brunch/service/user/axm/file/zRYOdwPu3OMoKYmBOby1fEEQEbU.pdf
http://t1.daumcdn.net/brunch/service/user/axm/file/Vw3RJSZllYbDc86ssL6bofiL4r0.pdf
PostPosted: March 11th, 2025, 22:50
Thanks fzabkar you are indeed living wiki when it comes to hard disks & electronics.
Possibly one of the person in the world having such indepth & comprehensive knowledge
PostPosted: March 11th, 2025, 22:54
Thanks fzabkar for the information but I spoke to Seagate chat while waiting for a reply and they said to replace them so out of an abundance of caution I will replace.
PostPosted: March 12th, 2025, 18:47
The only thing that would concern me is the Command Timeout attribute, but it only reports one "slow" sector. The actual number of seek errors is 0, and those read "errors" are actually just sector counts. I've provided you with Seagate's own specification documents. They explain the numbers better than I can.
PostPosted: March 13th, 2025, 10:13
https://www.disktuna.com/seagate-raw-sm ... ertertest/
Someone on another forum found the above which converts Seagates big scary numbers into sense.
Users browsing this forum: No registered users and 99 guests
