 Post subject: Repair 100815597 PCB
PostPosted: March 28th, 2025, 6:22
Seagate 8tera hard disk is not recognized even when plugged in.
pcb is 100815597 revd
The 12v diode in the picture comes with a short. Will be replaced.
If there's anything else you need to occupy, please let me know
Thank you.
 Post subject: Re: Repair 100815597 PCB
PostPosted: March 28th, 2025, 13:37
Thank you.
Check the small fuses.
Good luck
PostPosted: March 29th, 2025, 19:11
Thank you.
Good luck
It's been repaired well. Thank you
