 Post subject: WD10JPVX Still got BSY after Slow Responding Fix
PostPosted: March 25th, 2025, 12:51
Hi everyone. I have a drive that came in knocking. I have changed the heads and the drive comes in RDY however when got BSY when ID
I then proceeded to do Slow Responding Fix. Which did Upload LDR and module 02 normally. I backed up All SA modules. And tested which all gave green
However as soon as i Allow SA access and restart the drive. The drive hangs on BSY upon ID again
Can anyone help me out with this issue?? Many Thanks!!!
Model : WDC WD10JPVX-75JC3T0
Serial : WXC1A5739JJL
Firmware : 03.01A03
Capacity : 0 MB (1)
Family:................................. : FBLite 2.5"
Techno mode key......................... : Ok
HDD Status sector....................... : Ok
RAM:
System controller (SoC)................. : 88i9446C0 0x(A5C0)
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 256
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 256 Kb
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 157 871
SA regions address...................... : shifted
Module 02 access........................ : Granted
SA SPT.................................. : 0
ROM Modules:
ROM version............................. : 16.94G
Module 4F F/W version................... : 00160094
Overlay F/W version..................... : 16.94G
Servo F/W version....................... : NA.41
Heads configuration..................... : by map
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
Relocations............................. : 0 (0)
Read ROM DCM............................ : Ok
Power up log reading.................... : Ok
Power up load dir data.................. : No
Power up load permovl................... : No
Power up load CFG data.................. : No
NN | Step |    Time | Flags |     Info | Description
16 |  405 | 16.24 s |    3F | 51045499 | ACTUATOR_INIT(Unknown error code: 5499)
18 |  414 | 16.24 s |    3F | 51045499 | SPIN_DOWN_DONE(Unknown error code: 5499)
22 |  414 | 16.24 s |    3F | 51045499 | SPIN_DOWN_DONE(Unknown error code: 5499)
DCM in module 47........................ : AY
DCM in module 0A........................ : |Q|2AYX1HS
ROM Backup.............................. : <HDD Profile>\Data\SAAutoBackup\ROM\ROM-2025-03-25-23-37-43.bin
HDD SA blocking......................... : Ok
Drive power supply...................... : OFF
Drive power supply...................... : ON
Resources folder........................ : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\WDCMarvell\FBLite\16-94G-WDC ROM MODEL-FBLITE--03-01A03-WXC1A5739JJL\Data\Modules\Composed
Permanent ovl (11) data uploading....... : Ok
Module 02 uploading..................... : Ok
RAM:
ROM:
SA regions address (RAM)................ : by default
SA SPT.................................. : 1437
SA Translator loading................... : Ok
ROM Modules:
Overlay F/W version..................... : 16.95G
19 |  105 | 12.31 s |    3F | 5104370F | EXEC_POWERUP_LOAD_DIR_DATA(FM ERR HEADER II SIGNATURE INVALID)
46 |  105 | 12.68 s |   13F | 5104370F | EXEC_POWERUP_LOAD_DIR_DATA(FM ERR HEADER II SIGNATURE INVALID)
Service area:
SA dir reading (ID)..................... : Ok
Dir items loaded........................ : 505
SA Access............................... : Copy 0,Copy 1,Copy 2,Copy 3
Configuration reading................... : Ok
CFG tech mode lock...................... : No
Self encryption drive................... : No
Master Password......................... : has not been set
User Password........................... : has not been set
DCM in module 02........................ : S|BQL|P2MAHYCXR1VHKBUK
 Post subject: Re: WD10JPVX Still got BSY after Slow Responding Fix
PostPosted: March 26th, 2025, 1:36
check:
-if dir module is ok (probably coz pc3k inited itself from it, did it?)
-if dir address is ok in the active flash dir
-if active flash dir is ok
PostPosted: March 31st, 2025, 10:47
check:
well the problem was the heads after all. Even after swapping new pair of heads. The platter still killed those heads for no reason. Not sure how all Modules checked are green and the drive got ready normally
