 Post subject: HP SAS DRIVE [EG0300FBDBR] - NEED ADVICE
PostPosted: April 4th, 2025, 7:35
I have a 8 disks array server, 3 disks are spinning ok and detected on PC3000 SAS,
but there are 5 disks that are not powering at all. I do not think PCB issue since all of the 5 disk are same model and same behavior.
I did research some article mention about disable pin3 SATA power for power disable feature. I did that still no luck.
Just hoping anyone has similar experience and have some tips to share or any hided feature for these type of SAS HDD.
 Post subject: Re: HP SAS DRIVE [EG0300FBDBR] - NEED ADVICE
PostPosted: April 4th, 2025, 12:33
Do they spin up in the server? If not, is it possible that they could all have been clobbered by the same bad power supply?
PostPosted: April 4th, 2025, 19:56
The original server is fail, I have tried on new server, new NAS RACK they are not spinning at all
It just odd to me that the others 3 that working are different modal, but these 5 model are the same issue.
I wonder could it be possible that pin3 need 3.3v power to enter/exit power disable mode instead of not giving power to that pin?
PostPosted: April 4th, 2025, 20:05
Pin #3 should not be connected.
Can you upload a photo of both sides of one of the PCBs?
Users browsing this forum: No registered users and 37 guests
