ST2000DX001 not spinning up
April 16th, 2025, 23:10
This is an sshd drive which one day wouldn't spin up. I tested the diodes and fuses on the board. I removed one of the diodes because I thought it was bad but it wasn't. Does anyone have any suggestions?
Re: ST2000DX001 not spinning up
April 17th, 2025, 2:09
Hi! Show us the terminal output at device power up.
April 17th, 2025, 7:26
dbtractor wrote:This is an sshd drive which one day wouldn't spin up. I tested the diodes and fuses on the board. I removed one of the diodes because I thought it was bad but it wasn't. Does anyone have any suggestions?
Most likely a NAND related problem.
Post terminal output.
April 17th, 2025, 10:08
aekhv wrote:Hi! Show us the terminal output at device power up.
Can you tell me how to do that?
April 17th, 2025, 15:03
https://www.hddoracle.com/viewtopic.php?p=436#p436
Find a USB-TTL serial adaptor that can support 1.8V I/O.
April 17th, 2025, 22:49
fzabkar wrote:https://www.hddoracle.com/viewtopic.php?p=436#p436
Will this unit work? I assume I will need some software, what will I need to use?
https://www.amazon.com/dp/B075N82CDL?ps ... iewsAnchor
April 18th, 2025, 23:21
Actually looks like that other one I sent doesn't do 1.8 volts so this one should work I think https://www.amazon.com/gp/product/B08TX ... GFAQ&psc=1
April 18th, 2025, 23:29
That's a 3.3V / 5V device. You need one that supports 1.8V.
April 23rd, 2025, 9:42
My posts have to keep getting approved by a moderator not sure why,( I commented it last week) but I replied to your second to last comment with a 1.8 volt one
April 23rd, 2025, 13:19
That last one should be OK.
April 24th, 2025, 23:21
So it got delivered today and the connectors on the cables that came with are too big to fit in the connector on the drive. They look to be 2.5mm wide and I think 2mm wide would fir. What should I search for to get the right size?
April 26th, 2025, 13:01
fzabkar wrote:That last one should be OK.
I found some wires i had that I was able to use. I hooked up the rx tx and gnd with the rx, tx flipped on one end and hooked power up to the drive. I was able to get into the putty terminal and tried pressing control z but nothing would pop up on the terminal. The tx light on my adapter would blink each time I press control z and the rx light flashed when I supply power to drive but I couldn't get anything to show up in the terminal.
April 28th, 2025, 3:15
just copy the output the drive gives after powerup here
April 28th, 2025, 22:11
pepe wrote:just copy the output the drive gives after powerup here
Thats the problem its not giving an output. I need to know if i am doing everything right
April 29th, 2025, 5:53
if the rx led flashes a few times when you power the drive, then you should see something in putty. Have you used 38400/8/N/1 config?
try making a test by connecting RX to TX, then type any chars in putty, you should see them as you type (local echo must be disabled, otherwise you see what you type anyway, or see it doubled if RX-TX bridged)
April 29th, 2025, 11:12
I am using that config. my parity is none and flow control is none. I bridged the rx and tx on the adapter like you said and I was able to see what I typed. I was not able to before. I connected to the drive again and this time with the adapter already in the usb port and I got one cursor block of squiggly lines and once I powered the drive on I still get nothing showing up and I can't see what I type.
April 30th, 2025, 23:35
pepe, I am using that config. my parity is none and flow control is none. I bridged the rx and tx on the adapter like you said and I was able to see what I typed. I was not able to before. I connected to the drive again and this time with the adapter already in the usb port and I got one cursor block of squiggly lines and once I powered the drive on I still get nothing showing up and I can't see what I type.
