 Post subject: Remove ATA Lock on Toshiba Hard Drive
PostPosted: June 11th, 2025, 20:10
I have 4 Toshiba hard drives model: MK1060GSC that are ATA locked. The master password for Toshiba (32 spaces) is not working to unlock the drive and if there is a user password, I have no idea what that is. I do not want or care about the data, I just want to be able to repurpose the hard drives. From what I understand the password is stored on the platters so there has to be a way to wipe it.
I'm using a KNOPPIX LiveCD v9.1 to boot my older HP desktop (P6570) computer with the Toshiba being the only hard drive attached via SATA cable to the motherboard (not via USB).
sudo hdparm -I /dev/sda shows the following for Security:
Security:
    Master password revision code = 65534
            supported
            enabled
            locked
    not     frozen
    not     expired: security count
    not     supported: enhanced erase
    Security level high
    46min for SECURITY ERASE UNIT.
No matter what command I issue:
- sudo hdparm --security-set-pass tmp /dev/sda
- sudo hdparm --user-master u --security-erase tmp /dev/sda
- sudo hdparm --user-master u --security-set-pass tmp /dev/sda
- sudo hdparm --user-master m --security-set-pass tmp /dev/sda
I get the following error:
SG_IO: bad/missing sense data, sb[]:  70 00 05 00
00 00 00 0a 04 51 60 00 21 04 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00
In the computer BIOS I have tried setting the SATA Controller Mode to both IDE and AHCI. This seems to make no difference at all.
How do I remove the ATA lock so I can reuse these drives?
 Post subject: Re: Remove ATA Lock on Toshiba Hard Drive
PostPosted: June 13th, 2025, 0:29
If it was easy to remove security features from hard drives then anyone could do it. A data recovery professional may be able to do it.
Zero Alpha: zeroalpha.com.au
PostPosted: June 13th, 2025, 2:29
https://www.hddoracle.com/viewtopic.php?f=95&t=166&p=334
Users browsing this forum: Majestic-12 [Bot] and 33 guests
